Stupid question reg...
[Closed] Stupid question regarding disc brakes
Right i've ordered a new Deore front disc brake which is coming with an adaptor for a 180mm rotor. I have an Avid 180 rotor at the moment......will it be okay or do i need to but a Shimano one?
Sorry for the stupidity ๐Ÿ˜ณ
Posted : 28/08/2013 11:18 am
You'll be fine.
Posted : 28/08/2013 11:20 am
Should be okay, I've run Avid discs with deore brakes and Avid brakes with tektro and no-name discs before. If the diameters are the same any differences in width of the disc should be allowed for in the setting up of the caliper itself.
Not a stupid question either!
Posted : 28/08/2013 11:21 am
 cp
so long as your avid rotor is definitely 180 and and not one of the older ones at 185, you'll be fine.
Posted : 28/08/2013 11:23 am
Thanks Guys! don't feel so bad now ๐Ÿ˜€
It's from an Elixr 3, i'm sure it's 180
Posted : 28/08/2013 11:24 am
Try, check and see if the pads cover the rotor surface.
Posted : 28/08/2013 11:26 am
