strong reliable roa...
[Closed] strong reliable road rim?
[#6702500]
Can anyone recommend a road rim that's robust, reliable and reasonably light. Something that can take 32c tyres and a few rough roads. Stansted grail seems an option but is there anything else. Cheers.
Posted : 13/12/2014 10:39 am
Open Pros
Posted : 13/12/2014 10:44 am
 kilo
archetype, ailerons and pacenti sl25 all got mentioned positively on the recent cx wheel thread
I would have thought most rims would be strong and reliable nowadays, assuming that the wheel was well built and had an appropriate number of spokes if the rider was of a heavier build?
32mm tyres should add a fair bit of protection so far as flat spotting or other damage that you might not be able to true out.
As above, Open Pros or Archetypes.
Posted : 13/12/2014 11:24 am
see if CRC are still flogging wtb i19 cheap - 29er mtb rim but work OK with 28s IMO, probably even 25s
Rim has a UST-like ridge too, so hold a tubeless tyre well (actually a bit hard to unseat 😳 )
Posted : 13/12/2014 11:28 am
As above, almost all 400gm+ rims will do this.
Posted : 13/12/2014 12:23 pm
 benw
ambrosio excellence,they are balanced as well.they also look good which is after all the most important thing
Posted : 13/12/2014 12:33 pm
Open pro probably a bit too narrow for you. Something like an Archetype would do.
If you want strong and light then there are some wide Chinese carbon rims that seem well rated.
Posted : 13/12/2014 1:25 pm
Open Pro too narrow? What makes you think that?
Posted : 13/12/2014 1:27 pm
I have a set of open pro's and they are a bit old school in width. Fine for 23 but the op wants to run 32. Reckon they'd have a better profile on a wider rim. Even 25 are nicer on the archetype. All IMO of course 🙂
Posted : 13/12/2014 1:28 pm
Ah. I run 35mm cx tyres on Open Pros just fine. Cynic-al has run 2.3" mtb tyres on his, again with no issues.
FWIW, my cx tyres definitely had more "volume" on a set of Arch EX though.
Posted : 13/12/2014 1:52 pm
mrblobby - Member
Open pros and other rims were absolutely fine for decades.
Wide rims for road bikes is UTTER MARKETING SHITE
Posted : 15/12/2014 6:47 pm
Open Pro are not too narrow .I use them with 35mm Landcruisers on the 3 peaks cyclocross they are fine
Posted : 15/12/2014 7:02 pm
Just like narrow tyres have been absolutely fine for decades 🙂
Having ridden 25c tyres on OpenPro and Archetype rims, my personal preference is for them on the wider rims. You may prefer them on narrower rims.
There's a lot of marketing shite out there, but you could dismiss pretty much every bike product on that basis.
Posted : 15/12/2014 7:08 pm
Open pro will be fine for your needs?
Tough, cheap enough, eyeletted and good trueness out of the box so a competent wheel builder can provide you with well built, durable wheels.
Will accept a wide enough range of tire sizes to provide functionality.
Posted : 15/12/2014 7:55 pm
Why? I have no preference - because it makes **** all difference.
Posted : 15/12/2014 10:40 pm
OP - I presume you want a rim brake rim for road? If so, look at the Pacenti SL23.
Posted : 15/12/2014 10:48 pm
