Stripped bottom bra...
[Closed] Stripped bottom bracket.
[#1340779]
Hi, threads on the drive side of the bottom bracket have partially stripped, can these be repaired it's on a trek OCLV frame. Or can you get bottom brackets that don't use the threads?
Posted : 19/02/2010 10:11 am
if it's an aluminium insert you may be able to get an insert put in and rethreaded but the carbon frame could be a problem with that as they won't be able to ream out much.
google throws [url= http://****/2009/12/velo-orange-grand-cru-threadless-bottom-bracket/ ]this[/url] up as a threadless bb but I know others are available. [edit] didn't actually look at the picture, sorry!
Posted : 19/02/2010 10:15 am
IIRC posts before on here dont rate the threadless BB's as they move around etc but I have no experience with threadless BB. Try 😉 and search the threads on" threadless bottom brackets"?
[url= http://www.singletrackworld.com/forums/forum-search/?cx=016817152599703708915%3A6tudfkkai_w&cof=FORID%3A9&ie=UTF-8&q=threadless+bottom+brackets&x=0&y=0#993 ]linky[/url]
Posted : 19/02/2010 10:18 am
Try getting LBS to chase the threads - may be possible to save?
Otherwise, Trek UK may be able to replace the BB insert. 01908 282 626 ask for Gareth or Colin in service/warranty.
Posted : 19/02/2010 11:38 am
I think it's possible to get an insert glued into alloy frames, dunno re CF.
Posted : 19/02/2010 11:40 am
I'm very hard on my bikes, but I've never had the slightest problem with the BB threads - is it because BB's rarely last me as long as a year so they never get time to corrode themselves in ?
Posted : 19/02/2010 11:42 am
You should speak to Argos cycles in Bristol. Chances are that even with a CF frame there is a alu insert bonded in. I stripped the threads of my Alu BB (badly fitted BB cups - not by me)and they bonded in a piece of metal and recut the threads. Cost was £70 IIRC plus shipping each way. Very well done...you'd never know.
Posted : 19/02/2010 12:02 pm
