I track my running using the Endomondo app on my phone. After I've run I export it from the Endo website and import it into Strava. This has worked fine for me for years.
When I do this Strava imports the file and defaults to "Ride" activity type, I then change this to "Run".
Since the new year, when it's set to "Ride" all the stats look correct, however when I switch to "Run" it knocks a massive chunk of my "Moving time" making my "Pace" stupidly quick. The 2 screenshots below show the correct "Elapsed Time"; I wasn't stopped at any point, certainly not for the duration missing from the "Moving Time".
Interestingly my mile splits are stupidly quick, but any segments I run appear to have the correct/plausible pace...
Anyone any ideas what's wrong, or seen similar problems?
The files I export from Endo are GPX, I've tried TCX but Strava says it's an invalid file format...
Not a solution to your issue, but why not use Strava to record the run, and if you still want to maintain Endomondo details just export from Strava and import into Endomondo?
What do the map traces look like on Strava? Is it obvious from there where the time is lost (you can pan through the route and watch the timecode on the graph I think)?
is it that at times you're moving so slowly it thinks you've stopped, and is only counting 'moving' time as opposed to total elapsed?
This is only the 2nd time it's happened (only 2 runs since NY!) so I've not experimented much, but next time I'll try tracking with Strava and exporting to Endo instead.
The map trace looks fine in Strava, no obvious glitches.
My actual pace is between 7:00/mile and 7:30/mile; the only times I slow are for road junctions, but as I was running at 6:30am today there wasn't much traffic so I didn't need to stop at all.
You could try using the Garmin Fit app to record your run. This will auto-upload to Garmin Connect, which can be set to auto-upload to both Strava and Endomondo.
Following the Garmin Connect suggestion I imported today's run into there, and that shows some oddities too. I guess this suggests that the problem lays with the exports from Endo, rather than the imports to Strava;
The graph below shows my pace at either 30:00 or 0:00.
The Summary Stats look OK, but the detail shows a moving time of ":00"
Anyone see anything obviously wrong with this snippet from my GPX? The file just repeats these tags within a single trkseg, there's no pauses indicated.
[code] <trkpt lat="52.054006" lon="1.17199">
<ele>80.0</ele>
<time>2015-01-28T06:32:25Z</time>
<extensions>
<gpxtpx:TrackPointExtension>
<gpxtpx:hr>152</gpxtpx:hr>
</gpxtpx:TrackPointExtension>
</extensions>
</trkpt>
<trkpt lat="52.054002" lon="1.172299">
<ele>75.0</ele>
<time>2015-01-28T06:32:27Z</time>
<extensions>
</extensions>
</trkpt>
<ele>75.0</ele>
<time>2015-01-28T06:32:29Z</time>
<extensions>
</extensions>
</trkpt>
<ele>75.0</ele>
<time>2015-01-28T06:32:33Z</time>
<extensions>
<gpxtpx:hr>153</gpxtpx:hr>
</extensions>
</trkpt>
<trkpt lat="52.053966" lon="1.172566">
<ele>73.0</ele>
<time>2015-01-28T06:32:37Z</time>
<extensions>
</extensions>
</trkpt>[/code]
Just run Strava and Endomondo at the same time, that's what I do 🙂
Nice, it never even occurred to me that I could 😀
Looking at that GPX file extract, the middle three of the points are all at the same location, implying you were stationary betwee 6h32m27s and 6h32m33s. So whilst the file looks technically correct, either the GPS was having some problems locking on to satellites a lot, or Endomondo has screwed up the trace!
You could try using Tapiriik, it can copy between Endomondo, Strava, Garmin Connect etc. https://tapiriik.com/
You don't need to copy betwen garmin and strava, just link them, I'd be amazed if you can't do it with endomondo too
As above. Set up Garmin Connect to upload to both Strava and Endomondo. Works for me.
But getting the runs onto Garmin Connect would need you to either have a Garmin watch (which the OP doesn't) or recording with either Strava or Endomondo and then exporting and uploading to Garmin Connect - no fewer steps than exporting and uploading to whichever app / webservice he chooses in addition to the one he uses to log the run "live".
(Having said that, I use Sportstracker to capture the run, export from this, import to Garmin Connect which then pushes to Strava and FetchEveryone and then I manually upload to MyAsics - I'm not a good example of moderation in gpx uploading habits!!)
Whatever he chooses to do, it seems that Endomondo (or his phone) has screwed up the data with these runs.
larkim - MemberLooking at that GPX file extract, the middle three of the points are all at the same location, implying you were stationary betwee 6h32m27s and 6h32m33s. So whilst the file looks technically correct, either the GPS was having some problems locking on to satellites a lot, or Endomondo has screwed up the trace!
Well spotted! That's a bit odd.
I've just had another look at the GPX and there's bits like that all the way through it. Very strange.
I'll send an email to Endo and see if they comment.
[quote=larkim ]But getting the runs onto Garmin Connect would need you to either have a Garmin watch (which the OP doesn't) or recording with either Strava or Endomondo and then exporting and uploading to Garmin Connect Unless, as per my first suggestion, he uses Garmin Fit on his phone for actually recording the run in the first place.
Aha, hadn't spotted that. You've just cost me £0.69 in buying it to try it out!
I've knocked together a bash script to remove the duplicates and that's now looking fine. 🙂
Nice work on the script - care to post it? Could be useful for when the GPS plays up...
btw, on the Garmin Fit front. Not too impressed with what it appears capable of when running / riding. No audio feedback, no display of last lap time / average pace etc. Can see how it cuts out the uploading loop to Garmin Connect (and can sympathise with Garmin not wanting to produce an app which stops people buying their watches!), but the whole presentation of apps like SportsTracker etc when you're going along knock spots off the Fit app.
My script is below, not sure how much use it'll be to others as it's thrown together pretty specifically for my issue.
#!/bin/sh################################################################################
# Endomondo GPX exports appear to have duplicate co-ordinates at slightly
# different time-stamps. This makes anything you import them to think you
# were paused a lot.
# This script removes the duplicates. Verses - 28-Jan-2015
################################################################################# Check that a GPX file has been passed as a parameter
if [ -z "$1" ]
then
echo
echo "Please specify a GPX file to parse, e.g. $0 file.gpx"
echo
exitelse
gpx_file=$1fi
# Remove temp files and previous output files.
rm -f modified_${gpx_file} start_lines > /dev/null 2>&1# Get each line beginning with <trkpt and dump them in a temp file
grep -n "<trkpt" ${gpx_file} > start_lines# Get line number and text from line 1
line_a=grep -n \<trkpt ${gpx_file} | head -1
line_a_num=echo ${line_a} | awk -F: '{ print $1}'
line_a_text=echo ${line_a} | awk -F: '{ print $2}'# Copy all the header blurb into the new file
head -20 ${gpx_file} > modified_${gpx_file}while read line
do
# Get line number and text from next line
line_b=${line}
line_b_num=echo ${line_b} | awk -F: '{ print $1}'
line_b_text=echo ${line_b} | awk -F: '{ print $2}'# If next line doesn't match previous line output to new file, otherwise skip it
if [ "${line_a_text}" != "${line_b_text}" ]
then
echo "${line_a_num} and ${line_b_num} Don't match"end_num=
expr ${line_b_num} - 1sed "${line_a_num},${end_num} !d" ${gpx_file} >> modified_${gpx_file}
match_flag=0
else
echo "${line_a_num} and ${line_b_num} Match"# last <trkpt wasn't being written, use flag to track last one.
if [ ${match_flag} -eq 0 ]
then
last_trkpt_start=${line_a_num}fi
match_flag=1
fi
# Make current "next" line into "previous" line
line_a_num=$line_b_num
line_a_text=$line_b_textdone < start_lines
# Calc line number of last <trkpt
tmp_last_trkpt_end=tail -n +${last_trkpt_start} ${gpx_file} | grep -n "</trkpt>" | head -1 | awk -F : '{ print $1 }'
last_trkpt_end=expr ${tmp_last_trkpt_end} + ${last_trkpt_start} - 1# Add 1st instance of last <trkpt to the new file
sed "${last_trkpt_start},${last_trkpt_end} !d" ${gpx_file} >> modified_${gpx_file}# Add the footer lines to the new file
tail -3 ${gpx_file} >> modified_${gpx_file}
Feel free to critique/slate the code 🙂
You can use $(some-shell-command) rather than backticks to do
shell expansion, which means that it brackets properly (so if your command ever ends up with shell expansion inside it, it will still work) and more importantly, you can format it properly in STW.
i.e. like this:
line_b_num=$(echo ${line_b} | awk -F: '{ print $1}')
And you can get rid of the ugly start_lines intermediate file by piping directly into your "while ... do ... done" statement.
And add set -e at the top, or you won't spot errors.
Better still, use perl and an XML parser library.
Nice, not only did I not know that, I hadn't noticed they were missing above.
v1.1 below 🙂
# This script removes the duplicates. IJF - 28-Jan-2015
if [ -z "$1" ]
then
echo
echo
exitelse
gpx_file=$1fi
line_a=$(grep -n \<trkpt ${gpx_file} | head -1)
line_a_num=$(echo ${line_a} | awk -F: '{ print $1}')
line_a_text=$(echo ${line_a} | awk -F: '{ print $2}')# Copy all the header blurb into the new file
do
line_b=${line}
line_b_text=$(echo ${line_b} | awk -F: '{ print $2}')# If next line doesn't match previous line output to new file, otherwise skip it
then
echo "${line_a_num} and ${line_b_num} Don't match so appending"end_num=$(expr ${line_b_num} - 1)
match_flag=0
else
echo "${line_a_num} and ${line_b_num} Match so skipping"# last <trkpt wasn't being written, use flag to track last one.
then
match_flag=1
fi
tmp_last_trkpt_end=$(tail -n +${last_trkpt_start} ${gpx_file} | grep -n "</trkpt>" | head -1 | awk -F : '{ print $1 }')
last_trkpt_end=$(expr ${tmp_last_trkpt_end} + ${last_trkpt_start} - 1)# Add 1st instance of last <trkpt to the new file
I originally did try redirecting into the while rather than using start_lines, but couldn't get it working so reverted to "ugly-but-works" mode.
It's a very long time since I last used perl!
Just needed this again and found a slight issue with it so updated the script to cope. Originally I'd hard-coded the number of header lines to 20 (this worked with my original exports), but today's had 21 so I've adapted it to work out how many header lines need to be copied.
# This script removes the duplicates. IJF - 20-May-2015
if [ -z "$1" ]
then
echo
echo
exitelse
gpx_file=$1fi
line_a_text=$(echo ${line_a} | awk -F: '{ print $2}')# Find the line number of the last line of the header blurb
header_end=$(grep -n \<trkseg\> ${gpx_file} | head -1 | awk -F: '{print $1}')
head -${header_end} ${gpx_file} > modified_${gpx_file}while read line
do
line_b=${line}
line_b_text=$(echo ${line_b} | awk -F: '{ print $2}')match_flag=0
then
match_flag=0
else
then
match_flag=1
fi
