Strava noob questio...
[Closed] Strava noob question
So just had my first ride with Strava (yes, this could be addictive). Anyway, it picked up some of the segments I rode but not all. I tried to set up a new segment and then it suggested a list of similar segments that exist, which look more like the trail I rode than my plot. So is this just something I have to put up with - the fact it doesn't always track the route correctly? on an iphone btw...
Posted : 04/05/2012 7:29 pm
I stopped using the Strava app as this happened all too often. I used motion x then uploaded to gpx file.
Yes it is addictive, so addictive I went and bought a garmin edge 500.
Posted : 04/05/2012 7:35 pm
is the a stw table? Would be interesting to know whos the fastest..and the slowest on here!
Posted : 04/05/2012 7:44 pm
Yep, stw forumites, or something. Should know, I set it up 😕
Posted : 04/05/2012 9:15 pm
[url] http://app.strava.com/clubs/singletrackworld-com-forumites [/url]
Posted : 04/05/2012 9:32 pm
Good man! Would've done that myself but I'm on my phone.
Posted : 04/05/2012 9:41 pm
wait till you've definitely got a PB on a segment, and possibly a KOM and it doesn't register. heartbreaking...
Posted : 04/05/2012 9:43 pm
Strava is making me batter myself a bit on my commute. 2 KOMs today 🙂
Me too, I buried myself on a climb the other day and moved from 8th to 3rd. 🙂
Found out today there's a segment on the road almost past my house but because I've set the privacy settings to hide the area round me, it won't show up. This is annoying cos a mate is in 2nd and I know I can beat him!
Doing a Sportive tomorrow that uses timing by Strava - the organiser can't be arsed with all the transponder stuff and doesn't really believe in Sportive Timing anyway so all he does is put a few segments in on his routes.
Posted : 04/05/2012 9:46 pm
Move house 🙂
Posted : 04/05/2012 9:59 pm
I don't use it on the commute, only on weekend rides and extended weekday rides, using every day would be too much
Posted : 04/05/2012 10:06 pm
So you can't "tell" it you've ridden a segment, even though it registered you going through the start and end points??
Posted : 05/05/2012 10:11 am
Same here but if you ride away from your house then back towards the segment and head off again it'll pick it up. It's just the start and end of rides it hides
Posted : 05/05/2012 11:32 am
No you can't add it manually as such. There is certain criteria that is used to register the segment. It's all explained in the [url= https://strava.zendesk.com/forums/20539808-segments ]Strava Zendesk[/url]
You can email them with the details and request that it is added if you think it should have registered.
Posted : 05/05/2012 11:37 am
amen
just taken 57 secs off a KOM loop and it didn't register it - ****ers!
Posted : 06/05/2012 12:20 pm
How does it work? Do you record a full route but if you ride between a segment it is supposed to pick it up for KOM etc?
What I mean is I dont have to start at point A press start then finish at point B and press stop?
Posted : 14/02/2013 5:30 pm
Just record a full ride and it should pick up all the segments you go through, whether you know they're there or not.
Posted : 14/02/2013 5:36 pm
Thought that would be the case. Cool cheers.
Posted : 14/02/2013 5:42 pm
Like anything in life the key is to use the right tool for the job. In this case, for recording a GPS track, you're better off using a GPS unit rather than a telephone.
Posted : 14/02/2013 6:12 pm
[quote=timmys said]Like anything in life the key is to use the right tool for the job. In this case, for recording a GPS track, you're better off using a GPS unit rather than a telephone.
Personally I use a telephone which happens to be a GPS also 🙂
Posted : 14/02/2013 6:23 pm
[i]a telephone which happens to be a GPS also [/i]
although telephone's have pretty average gps capabilities compared with a dedicated unit.
Posted : 14/02/2013 6:24 pm
I am aware of the concept 🙂
However, using a GPS that is; a) more accurate in the first place & b) usually on the bars rather than in a pocket, is a big help when you are trying to record a ride accurately for Strava.
Posted : 14/02/2013 6:32 pm
 Kato
wwaswas - Member
This. I've had no problems recording tracks since I bought a Garmin. When I was using my iPhone it was all over the place. Plus the phone would be flat within about 2 hours
Posted : 14/02/2013 6:33 pm
+1 for garmins, or even better a GPS logger you can leave in a jersey pocket, I reckon my £20 one off ebay was even more accurate than my edge as it had a better view of the sky (someone else did some testing with a forerunner on their wrist with similar results).
Why pay for the sportive then? Park in the same place the next day, without having to fight for a place, ride the loop navigating by GPS, then spend the £30 on as much cake and coffee as you can consume at regular 'feed stations' and be glad it's not SiS and half bananas.
I enjoy sportives, but I'd not pay for one!
Posted : 14/02/2013 6:42 pm
Think that might just be an iPhone issue,no such problems with my budget Chinese Android phone 🙂
Posted : 14/02/2013 6:44 pm
[i]Chinese Android[/i]
like normal Android but with more pictograms?
Posted : 14/02/2013 6:45 pm
