Straightening brake...
[Closed] Straightening brake rotors in the oven?
I'm sure I heard about this ages ago...
anyone tried it? did it work? what did you do?
Posted : 15/07/2009 11:54 am
rubbish!
just use an adjustable spanner, it's easy ๐Ÿ™‚
Posted : 15/07/2009 11:56 am
ditto,
average home oven 250degC
melting point of steel 1250degC
How exactly will an oven help?
Posted : 15/07/2009 12:00 pm
If your oven tops out at around 1000C it might work, mine stops at 220C
How about putting an oven inside an oven inside an oven inside an oven..
Posted : 15/07/2009 12:02 pm
Get the spanners out!
Posted : 15/07/2009 12:07 pm
Jesus!!! next you'll be telling him he can't straighten his Skyway mag wheels in the freezer too! ๐Ÿ˜‰
Posted : 15/07/2009 12:13 pm
hmmm, going to look in to this as my bike nearly fell off the car roof on the way back from the lakes on sunday and the rotor, which took all of the impact when it all went horizontal, now resembles a pringle!
surely you dont want to be melting the thing just soften it up, so why would you need to get up anywhere near 1000degrees?!
Posted : 15/07/2009 12:14 pm
...or that a fish slice doesn't make a handy tyre lever ๐Ÿ™
Posted : 15/07/2009 12:15 pm
because it won't be soft at 1000°C
Posted : 15/07/2009 12:16 pm
Are you confusing brake pads in the oven to remove oil contamination with brake rotors?
Posted : 15/07/2009 12:18 pm
 devs
Just use a hairdryer on its hottest setting. That'll be sufficient
Just rub it gently and channel your thoughts into it.
Posted : 15/07/2009 12:20 pm
you don't need to turn it on, just hit the disc in the right direction...
and don't use any styling gel!
Soak in tea and pop under the grill . . .
or just buy a new rotor?
Posted : 15/07/2009 12:23 pm
๐Ÿ™„ obv don't want to melt anything and an oven won't be enough for phase changing then quenching
I thought that there might be a little truth in it - that 300 C might enough for stress relieving purposes, but I think you'd need closer to 500 C for that.
*sigh*
let the rollocking continue
Posted : 15/07/2009 12:27 pm
lightly fry in extra virgin olive oil with plenty of chopped garlic - mmm - mmm...
Posted : 15/07/2009 12:28 pm
You need some straightening tongs
Posted : 15/07/2009 12:36 pm
 jwt
LOL @ Uplink!
Posted : 15/07/2009 12:54 pm
Remember to use this afterwards
Posted : 15/07/2009 12:56 pm
Find a big, long hill, ride down and let your attempt to stop strighten it out.
Posted : 15/07/2009 12:59 pm
I wouldn't be without my straightening tongs in the workshop
Posted : 15/07/2009 1:03 pm
[b]glenh - Member[/b]
That's a good call actually. Maybe Uri Geller can set up shop as a rotor straightener now his main job of being a 'friend of Micheal Jackson' has come to a close.
Posted : 15/07/2009 1:04 pm
Did you actually just go and borrow your wifes hair straighteners, run out the garage, hang them up, take a picture, put the picture on the computer, upload it, then post it here. Or do you just sometimes feel that your hair just isnt straight enough while out fixing the bike.
If its the first one, thats commitment. If its the second, you have a problem.
Posted : 15/07/2009 1:10 pm
๐Ÿ˜€
Substitute daughter for wife in the first option & you're somewhere there
I'm not sure you can straighten 1/8" long hair by any substantial amount
Posted : 15/07/2009 1:14 pm
You could try really hard.
Posted : 15/07/2009 1:16 pm
[i]you[/i] might not be able to - but i bet Chuck could.
Posted : 16/07/2009 1:32 am
lol uplink. worth going out!
Posted : 16/07/2009 2:12 am
