Storing bikes verti...
[Closed] Storing bikes vertical and reverb
Posted : 04/01/2013 11:09 am
Its dirty because mud get thrown up off the back wheel onto the post, you use it and some mud get past the seal.
Solution - fit a crud catcher / wash it.
Water gets inside your frame when you wash the bike (via the headtube when/if you wash it upside down), this drips out of the hole in the bottom bracket. This will also put muddy water on the bottom of your seat post.
Solution - make sure you dont put water in the frame, clean the seat post now and again, make sure the drain hole in the bottom bracket isnt blocked with mud.
Posted : 04/01/2013 11:17 am
Hmm question has gone...
I use a strip of inner tube zip tied to the rails and base of post to keep it clean
Posted : 04/01/2013 11:20 am
