Stooge Cycles - who...
[Closed] Stooge Cycles - who's interested? (slack 29er content)
 gil_
STATO...I wasn't offering you a test ride, mealy suggesting you might not need a Large frame
I guess your user name is quite appropriate 😆
Posted : 24/08/2015 11:38 am
Newcastle. The point is though im not really in a position to test ride time wise (to take a bike somewhere to get a decent ride on it) and im not especially looking for a bike.
My point was the information about the bike is limited so a lot of people must be dismissing it as too small, some more geo information or explanation of how the 'fit' works might help. Suggestion to run a layback post (on an already slack seat angle) without any explanation of fit just makes it sound even smaller. I was interested when this thread first started on the principle of a slack 29er, but turned away when i saw the geo and have not bothered going out my way to test it.
I totally appreciate its designed to work/fit differently, im not dismissing it or suggesting its a bad bike (clearly enough evidence in this topic to confirm otherwise) but different either requires 'different' people to buy-in on principle (or looks), but to persuade others (especially taller folks used to bigger bikes) requires more info (IMO).
Posted : 24/08/2015 11:52 am
Probably 😆
Ive ridden enough small frames in my time to know what i prefer, but still open to other theories (im a stato in love of stats, not a 'this wont work' opinionated type).
And my point about a test ride is that unless you have time to set it up how you like (or in the case of quirky designs, learn to understand how it should be rideen), there will probably be something that will put you off.
Posted : 24/08/2015 11:55 am
Newcastle.
Bykology in hexham might have one
Posted : 24/08/2015 12:09 pm
Anyway, to defend the request for larger frames
from 3rd page of thread
Regarding the one size fits all - that's not really my ethos, but at this stage it's economy of scale coming into play. The frame really does build up big (100mm stem etc, builds up huge, in fact), BUT, if it proves succesfull and there's enough genuine demand then i will certainly build both larger and smaller frames as required.
Tho to be honest and complete the quote, it did also say...
As it stands, the frame handles sooo well on tight, technical trails. It's been tested by riders from 5'6 to 6'2 and neither had a problem with fit.
Posted : 24/08/2015 12:22 pm
[Had my first ride out on my new Stooge yesterday and noticed how well the Chronicle flicks up grit when it gets a bit sticky!
What are people using for mudguards - does the Mucky Nutz Face Fender or Mudhugger fit ok? Any suggestions for the rear..?]
I've Mudhuggers. The rear keeps me clean, the front with the extension is no match for a Chronicle, or at least the Chronicle can get stuff past it. Probably better than without. Knard didn't get so much past it. Am thinking of of fitting a homebrew longer extension
Posted : 24/08/2015 2:31 pm
hurry up and make a 650b small
+1
Posted : 24/08/2015 2:34 pm
Something I've been meaning to ask. Is the head tube still 11/8" straight on the mark 2 frames? Or is there an option to run a tapered steerer fork?
Ta.
Posted : 24/08/2015 8:50 pm
Straight 1 1/8" steerer on the steels, 44mm on the Ti. I run an Enve fork in mine (tapered steerer) with a Hope mix and match headset - integral upper, 1.5" external lower.
Posted : 24/08/2015 10:08 pm
due to popular demand i'll be adding these figures to the geometry chart in the next few days 😉 reach = 427mm stack = 584mm
I'm an old fashioned ETT man myself. I think the reach figure of the Stooge is the same as a size L Bronson, for what that's worth.
re the headtube size, i decided to stick with the regular 1 1/8th for a couple of reasons, firstly a 44mm would ruin the lines, and secondly there aren't any carbon forks (other than the Enve) that have the correct geometry. The frame and forks really are designed to work together.
Posted : 24/08/2015 11:18 pm
due to popular demand i'll be adding these figures to the geometry chart in the next few days reach = 427mm stack = 584mm
thanks, longer than expected. Same reach as my old Large Spearfish, bit lower too.
Posted : 25/08/2015 10:30 am
Quick question for owners how do they climb?
Is it more winch slowly / SS grunting / mild chore to the top or a bit more lively/xc in nature (appreciating it won't climb like an xc race bike obviously).
Posted : 25/08/2015 10:41 pm
Best I've tried, especially on somewhat technical climbs. Compared to: On-one 456, On-one scandal, Grand Canyon AL.
Posted : 26/08/2015 8:33 am
So plugging these numbers (reach = 427mm, ETT = 597mm, stack = 584mm) into my old trusty calculator I get like 73.7deg for effective seat angle (website says 72 deg). Should I check my math or is something wrong here?
Posted : 26/08/2015 9:40 am
Very well! Mines setup singlespeed so on some steep climbs I have to stand and mash. With the long TT its comfortable to do that and you don't feel to far over the front of the bike. Sitting and spinning is also easy enough. I think the front is more stable than my Whyte T129 on the climbs when sitting.
Posted : 26/08/2015 9:46 am
The seat tube is bent, so 72 at its uppermost, but (as you show with your maths) the effective angle at the point of intersection at the level of the headtube. Of course this means the seat at riding heights will be further back than a 73.8 would have you expect, due to the actual being 72.
Posted : 26/08/2015 4:43 pm
Excellent climber. Maxxis Chronicle Fr, Nobby Nic 2.35 rear. 3x10. Really just digs in to the hill and you go.
Posted : 26/08/2015 4:46 pm
I'm going to go B9er - slacken her up even more!
Posted : 26/08/2015 4:53 pm
Just a quick thanks to the bods who responded to my climbing post. 😀
Posted : 26/08/2015 8:01 pm
In light of the recent weather I decided to give a Mudhugger (FR) a try to keep the grit out of my eyes:
Fits pretty well (with just the modification to add the top straps) and seems to stay in place, but only time will tell. If I can lay my hands on a heat gun (hairdryer didn't really cut it) I will try and mould the 'shoulders' a bit so it sits a little higher - will also keep it in place better too.
Posted : 27/08/2015 2:35 pm
Looks quite discrete
However, it does seem a tad low for clearance
I used a crud catcher last winter which worked well
Posted : 27/08/2015 3:27 pm
[quote=bonesetter]However, it does seem a tad low for clearance
Clearance is about 8-10mm and should improve once I've modified the shape a bit.
Posted : 27/08/2015 3:34 pm
dalhalvaig will be along in a minute...I think he's had mixed success with his. Keeps the face splatter free but that's about it.
Posted : 27/08/2015 3:45 pm
Doctor on call...
Yes mixed result with my Mudhuggers. The rear definitely keeps my saddle and back clean and dry, the front is keeping a lot of muck off my face, but not everything. I get spray up the from of my jacket/shirt, so am thinking of making a longer extension. I have the Mudhugger extension. The Chronicle gets more past it than the Knard, but the Chronicle clears mud quicker...onto me as it turns out.
You can see below where the mud is getting to...this was with the Knard.
[img] https://lh3.googleusercontent.com/nFEBnv_ydHH-__VC1hkacJa4KdWaGxe36IheJWPpx-Y=w940-h705-no [/img]
Also the Chronicle has a wider shoulder than the Knard and can scuff the Mudhugger, so am planning another set of tie-wrap holes just below the curve at the top of the fork
Posted : 27/08/2015 3:59 pm
That grass needs a wee trim & the shed could also do with a paint...have you been sitting on your backside all day?! 😀
Posted : 27/08/2015 4:02 pm
That's not even my house!!
Posted : 27/08/2015 4:04 pm
Posted : 27/08/2015 4:11 pm
Hi, Are there any Stooge in Devon or the SW that can be tried out / demoed?
I was lucky enough to have an evening riding a Jones with a Fat Front and a Jones Plus around my local woods this week, courtesy of Peanut off here and I am hooked. I think the standard Jones and Fat front suited my riding style best of the two. But it was very close. I need to try a Stooge now to add to the complication of which is best for my needs.
Posted : 04/09/2015 8:04 am
I'll be Stooged up in the Padstow area from the 18th if that helps?
Posted : 04/09/2015 8:11 am
Spectabilis - thanks for the heads up. Just looked at the Calendar and I may be free that weekend. Not too far for me to travel either. Cardinham trails about 30mins drive from Padstow....I'll chase you up if it works out.
Posted : 04/09/2015 8:36 am
julioflo:
Charlie the bike monger has one in the shop running 27.5+, spoke to them today about these bad boys.
I'm seriously looking at getting a magenta frame and building it up over winter. with the gen 2 frames, is anyone going 29x3" front and rear, or 27.5+.
I've got a full fatbike which can run 29x3, but really fancied one of these.
after speaking to one of the really helpful guys in Charlie's, he was saying it'd be better running 27.5+. Can any of you current owners give some input. it's probably going to be 1 x10 gearing, (as I'm not man enough yet for single speed). wanted to go half fat with the tyres as well. what rim widths are you folks running, and how big a tyre have you safely shoehorned on there.
Posted : 10/09/2015 6:40 pm
I have a Ti stooge running 27.5+ and will prob not go back to normal 29 on it now after a fair few rides ...it's the best of all worlds
Posted : 10/09/2015 9:05 pm
...but he's ^ never tried 29+ on front .... But then I've never tried 27.5+!
Posted : 10/09/2015 9:19 pm
I have tried 29x2.5 and I have a fatty .....too much rolling wieght for my liking I'm afraid Clink
Posted : 10/09/2015 10:21 pm
Just lay off the ciders for a bit 😆
Posted : 10/09/2015 10:51 pm
No way ..that's just stupid talk....oh and weight obviously. .must read text before posting
Posted : 10/09/2015 11:05 pm
New tyre time ...Just checking out these Goma TNT's from Vittoria
This is a 29x2.4 on a Dually in a MK1 frame, comes up LARGE slighlty bigger than the Chunky Monkey that was on previous going to have to swap for the 2.25 I reckon.
[img] https://lh5.googleusercontent.com/-utgFwNSlPC8/VfLGtHjnW5I/AAAAAAAATps/rbJjLDtgvd4/w637-h849-no/2015%2B-%2B2 [/img]
[img] https://lh3.googleusercontent.com/--DOpV3aLwEM/VfLFQN7o-dI/AAAAAAAATo0/Fu9zwMfhIuE/w637-h849-no/Bike%2BShit%2B-%2B1 [/img]
Posted : 11/09/2015 1:27 pm
Evil sovereign-
The new frame will take a 29x3 on a thinner rim but if you were going to run 29, especially in the winter, it will still work best with a 2.4, there's plenty more clearance on the new frames, so the tyre in Spectabilis' picture will fit without problems (sorry Spectabilis 🙁
As for 650+, if you enjoy hooning down technical singletrack and hopping off and over things then its great, it does really good things to the bike's handling and flickability, just feels a bit more hooligan - but if your riding is more long day in the saddle then the 29er probably wins. The Stooge geometry is designed to have a slightly larger front tyre so if you were running B+ i'd recommend either a 3.25 front/3 rear or a 3/2.8 combo,though i guess it wouldn't be that important.
From experience, a 2.8 on a 30mm rim spins up lovely, feels really light, a 3.25 feels a lot more draggy. If you're going to run a 40mm plus rim on the back, make the 3.00 your largest back tyre.
Hope that helps. Have a word with Charlie too 🙂
Posted : 12/09/2015 8:00 am
Has anyone tried 650+ and 2 x 10? Just wondering what the clearance is like and wether I need to have a rethink before taking the plunge.
Posted : 12/09/2015 9:17 am
back to the geometry discussion for anyone who is interested.. I wanted to understand those numbers.. so I checked again the drawing on stooge website - here is what I get: stack 625mm, reach = 405mm, effective seat angle = 73 deg
Posted : 12/09/2015 10:00 pm
julioflo - Member
Unfortunately a change of plans means I can't take it with us now, sorry for any inconvenience.
Hope you get the chance to try one soon.
Posted : 18/09/2015 11:53 am
So has anyone tried anything bigger than a 29+ on the front of their Stooge? I'm thinking the on one carbon fatty forks which maintain the 55deg offset but running 26x4.8?
Posted : 20/09/2015 2:52 pm
Anyone got pics of their 27.5+ set-ups?
Posted : 23/09/2015 2:30 pm
I'm struggling to find a rear 27.5+ wheel!
They all seem to come in pair or have boost axles.
Is there anyone selling 27.5+ rear wheel builds with 135xQR?!
Posted : 23/09/2015 2:38 pm
bonesetter....
Take a look at @StoogeCycles's Tweet: https://twitter.com/StoogeCycles/status/645365888972124160?s=09
Posted : 23/09/2015 5:39 pm
Page 23 / 33
