Stockpiling bike pa...
[Closed] Stockpiling bike parts
Pre covid I normally purchased bike parts on an "as needed basis". Now with all the stock supply issues I'm curious as to how much everyone has changed their bike part buying habits? How many consumable parts such as tires etc do you stock up on now?
For me, I've been trying to make sure that I have at least one spare set of tires, chain, cassette and brake pads at all times but even that has been difficult to do.
Posted : 19/12/2021 9:18 pm
I bought a saddle , seat post and some tires for a new build.... But no panic buying here.
Posted : 19/12/2021 9:22 pm
I wasn’t - but now I’m like, ahhh panic!
I reckon you only need stuff in that’s likely to break, wear and tear items should be predictable enough to order. So for me it would be tires, mech and hanger, bottom bracket, spokes, valves, bearings. But I have none of these in so will start having a look
Posted : 19/12/2021 9:24 pm
No more than usual but I've typically always kept a good stock of consumables. In fact, I'm probably buying less than usual.
I'm certainly not panic buying as that just causes other to panic buy.
Posted : 19/12/2021 9:28 pm
Yep - I definitely have more spares in stock - two complete spare drivetrains, one for each bike - I usually have quite a few tyres kicking around, but do have one or two more now
Posted : 19/12/2021 9:33 pm
Four bikes here, so a bit impractical. Always got spare tyres anyway. Specific spares are a chain ring for the commuter MTB, as it's running a rare Shimano LX M570 crankset with 5 arms - rings are a bit tricky to get due to age. My main FS is a SRAM 2 x 10 and it's the rings on that that are hard to get for a reasonable price, but I start looking as it starts to wear.
Road bikes don't wear parts anything like as quick, and the standards tend to stay the 'same' for longer. Road bikes are vintage Shimano 600/Ultegra and Dura Ace - both 8 speed so parts plentyful.
Posted : 19/12/2021 9:34 pm
I have one spare chain of each type we need for all the bikes in the house.
I have spare brake pads for 80% of the bikes.
Probably got a few old 11 speed cassettes that could be pressed into service if needed, got a set of wheels that need fixing but otherwise ok.
Posted : 19/12/2021 9:37 pm
I only 'stockpile' consumables so in stock currently I have chains, brake pads and rotors, cables, bar tape and set of tires. I tend to operate a one in one out policy
Posted : 19/12/2021 9:52 pm
I never stockpile due to shortages but if there's aver a real bath then I've been known to buy a couple of extra items. I've mostly got a lot of tyres right now.
Posted : 19/12/2021 9:53 pm
Forgot to mention spare pads - that goes without saying, and a spare 10 speed chain.
Posted : 19/12/2021 9:59 pm
Shimano LX M570
Will look in the shed, I have an LX vintage crank rings in the shed that might be what your looking for.
Posted : 19/12/2021 10:06 pm
I always try to keep in stock one spare of anything that could catastrophically break and potentially ruin a weekend's riding i.e. chain, cassette, chainring, rear mech, shifter, and bottom bracket.
Also, a decent stock of consumables (gear cabling, brake pads, quick links, oils and greases etc).
Things like frame bearings, headset bearings, wheel bearings etc don't seem to catastrophically break for me, touch wood, so I just tend to buy them as and when things get notchy and gritty.
I've also got a general parts bin (low end / stock stems, bars, grips, saddles etc) for emergencies, but again, these never seem to go wrong for me.
Posted : 19/12/2021 10:17 pm
Got a spare chain and cassette but that's just because decent 10sp is getting hard to find.
Always have lots of spare brake pads, buy I in bulk as it's cheaper,I need three kinds across seven bikes so not too bad
Posted : 19/12/2021 10:35 pm
I stockpile stuff, then forget what I have.
I bought a new 11 spd chain in the year, only to find two brand new ones in ‘the tub’.
Posted : 19/12/2021 10:52 pm
2 chains, cassette and mech hanger. Hopefully that will keep me going. Thinking I should have a spare tire now..
Posted : 19/12/2021 11:00 pm
I’m curious as to how much everyone has changed their bike part buying habits?
Not at all. I usually do my buying late at night after relaxing over a few drinks. Then I decide I need something. I should probably go out to the shed to check if I already have one in stock, but I figure that having a spare is good anyway. I always order two, just to make absolutely certain I have a spare for the next time.
I'm not really sure. My shed is full of boxes of spares. I should probably do a stocktake, but that would mean restacking the mountain of 26" tyres I bought just in case they stop making them. Can't be arsed, easier to just buy stuff when I need it.
Posted : 19/12/2021 11:27 pm
No stockpiling, but I'd really like a 27.2 Thomson seatpost which appears to be impossible.
If anyone happens to have one, give me a shout.
Posted : 20/12/2021 12:25 am
 feed
Haven't changed at all as I was always dreadful for buying stuff when PSAs came up. Thankfully they're less frequent these days so I'm getting to run the stock stash down a bit.
Posted : 20/12/2021 1:24 am
I've been preparing for a parts shortage for 20 years it seems.
Posted : 20/12/2021 2:13 am
I've stuff left over from a 2x10 build i never got around to doing. New rotor rex cranks,xo 10spd mechs and shifters, hope BB,stem and e4 brakes plus the 10spd xt cassette and chain.
Dont need it all at the moment but this drought seems to be going on indefinitely, so best hung on to I reckon
Posted : 20/12/2021 3:34 am
I've just rebuilt the drivetrain on the Enduro and I think for the first time ever I couldn't buy all the bits I needed from one store, had to go to Italy for the cassette and a few parts aren't OEM (BB and jockey wheels) it'll probs be a while till I try doing that again as it was a palaver.
I always aim to have spares like cables and pads and stuff.
Posted : 20/12/2021 8:29 am
I'm working on a retrograde system.
I replace anything that breaks* with the perfectly serviceable "out of date" stuff I took off.
As I am still running late 90s 8speed stuff which just won't die or singlespeed, I'm not too concerned.
*Which it doesn't.
Posted : 20/12/2021 8:34 am
I haven't sold my RD-M760 mech. Not because I'm worried I might need it but because I'm lazy. I'd sooner go chainless than run that abomination again.
Posted : 20/12/2021 8:36 am
I bought four tyres before I moved to Sweden, but I do still run 26" on the stumpy, so it made sense to. And they were on special.
Posted : 20/12/2021 9:13 am
As above. My ‘stockpile’ is a result of upgraditis and being too lazy to move stuff on.
Posted : 20/12/2021 9:16 am
Rather a lot of 26” 9sp 1+1/8 straight rapid rise stuff, as I’ve decided to keep my old orange 5 till I’m in an urn (*and the mrs still rides her old myka) and luckily, as I went electric quite a few years ago I have a fair bit of 11sp consumables built up before it went all silly.
Posted : 20/12/2021 9:52 am
brake pads and a spare 12 speed eagle GX cassette is the sum total of my 'parts bin'.
I always keep my eye out, but generally are too tight to actually buy spares, as touch wood.... i dont go through that many parts (thankfully)
Posted : 20/12/2021 9:57 am
I’ve been preparing for a parts shortage for 20 years it seems.
+1
If anything I've probably run down the spares a bit over Covid.
Posted : 20/12/2021 10:11 am
Yeah. Always have a decent stockpile of stuff. Chains, tubes, gear cables, brake pads, often cheaper in bulk and since they get used... Will also grab tyres when I see stuff I like on offer.
Majority of our bikes are 10 speed, which simplifies things a bit.
Posted : 20/12/2021 10:14 am
 DrP
As above i frequenly have a decent buffer of stuff as and when I swop or upgrade bits (i.e i've an NX 12spd deraillier in the garage, as i upgraded to AXS.
Many handle bars, many SPD pedals..
The only thing i actively recently got due to shortages was 2 GX 12spd chains... Our E bike and my stumpy are both SRAM 12spd, so seemed sensible to have spare chains.
Oddly, i really MUST get more brake pads in stock as i literally have no spares!!
DrP
Posted : 20/12/2021 10:23 am
Pretty much no spares here.
I go in a wee loop of thinking I should get a 12 speed chain, then mibbe a cassette, then I remember the price of them, and don't bother. I'll ride them til utter death, and then worry about it.
Posted : 20/12/2021 10:26 am
I tend to keep quite a bit in but I realised over lockdown that I had a load of stuff that might come in handy one day but I'll probably never use. I had a big clear out on eBay and now have a more measured collection of spares. I do need some 10 speed chains in if anyone has seen a deal.
I have over done it on a few things. I recently bought some bargain brake disks opened the spares draw to put in them away and found it to already be full.
Posted : 20/12/2021 10:28 am
I have always kept a decent stock of consumables and spares.
Posted : 20/12/2021 10:30 am
I’ve got a spare xo1 mech and chain that I bought before going to Morocco a few years ago. They go with me on any long trips. Other than that and the pile of old junk I refuse to dispose of, I’ve the usual pads, shifter cables and fluids. I’ve also got at least two of each spoke type that the bikes might need.
Posted : 20/12/2021 10:44 am
@nickjb I get my chains from Decathlon. Usually 12-15 for their 'BTwin' stuff, which is made by - and branded - KMC.
Posted : 20/12/2021 11:01 am
Any deals on decent level (SLX or KMC X11) 11-speed chains?
And 11-speed-compatible quick links?
Posted : 20/12/2021 11:03 am
 edd
I try to keep no stock of anything. In practice I have a spare set of brake pads (and my old frame and reverb, both of which I'm trying to sell). Worried about where my next 12 speed Shimano chain will come from, might try to find one...
Posted : 20/12/2021 11:15 am
I’ve got a bit more stock than normal because I also commute on my MTBs and the electric one eats drivetrains annoyingly fast. So I’ve got a spare cassette and chain for the hardtail, a few cassettes and chains for the Levo and a spare rear mech, and quite a lot of tyres. I usually get my LBS to do most stuff because they’re good and I’m short of time.
In my defence my hardtail is about to turn from 27.5 to 29 and the Levo needs new tyres so the tyre mountain will soon be smaller! Am going to get some singlespeed stuff for the hardtail so that has an alternative in case I wreck a 12 speed mech and can’t buy a sensibly priced one.
Posted : 20/12/2021 11:21 am
Always kept a spare chain or two anyway and brake pads, as these can suddenly go. Nothing else new though. Probably pick up a gx eagle cassette if they ever come back in though, just because I don’t know when next resupply will come in. Main bikes both on eagle 12spd with guide brakes, so spares cover both.
Stuff like bb and chainrings pretty much always available from superstar or Uber bike, so no real worry there.
Various part worn tyres, but ebike and full sus both 27.5 so always an easy swap over. Certainly no new spares.
Spare cassette and chain for gravel bike, but these are part worn, taken off mtb when I changed to 12spd.
Lucky to have a decent range of bikes, so any unexpected breakages just mean a different bike choice.
Posted : 20/12/2021 11:33 am
@saccades
I urrently have a new spare big ring, but do swwm to chew through them espeially as it's the commuter/shoot weather bike - if it's just tracks, canal etc, then I take the old bike out.
It's the 94 PCD 5 arm, the outer ring is a blue grey colour with the word 'MEGA'
Posted : 20/12/2021 1:51 pm
 momo
A good collection of spare tyres, although you could also call this having tyres for all conditions!
Have a spare chain for the main MTB (XO1 eagle, I bought two when i first went eagle 3 years ago, still haven't worn the first one out!)
Apart from that, I've cleared out most of the old stuff on eBay this last year.
Posted : 20/12/2021 3:02 pm
My most used bike is of a certain vintage, so I do have a stock of stuff you can’t get any more (or you can, but with difficulty/expense when you actually need them). I have two complete sets of Middleburn chainrings and about 10 sets of Hayes semi-metallic pads for the stroker gram. Once they’ve all been used up, it might be new bike time… If I see something at a good price that I know I will definitely use, I’ll usually buy it if I can and stash it in the loft until I need it.
Posted : 20/12/2021 3:11 pm
I always have spare cables, hoses, olives, barbs, pads. I have chainrings and other slightly used parts or the occasional bargain I’ve picked up for one of my kids builds. Otherwise, no real stockpile - unless you count a stash of parts that were cutting edge between 1988 - 1997 or so.
Posted : 21/12/2021 12:38 am
I have bought a couple of pairs of 29+ tyres because they are hard to get and I fear they may disappear altogether. So far they are still in their packaging but I wonder if storing them like that longer term will wreck them an I will end up with a creased and distorted tyre…?
Posted : 21/12/2021 10:18 am
When it became apparent that finding parts was going to be a problem – so, summer 2020 – I started buying stuff that I knew I'd need for both my bikes. So now each has a spare chainring, a cassette or two, a chain, brake pads and cables. Most have been sourced at below RRP by doing a bit of sniffing around (the exception: GRX chainrings). Got a few tyres knocking about so have only bought one DHRII and DHF. Thankfully, most of the stuff I need is pretty standard.
Posted : 21/12/2021 4:01 pm
I keep a single spare of most stuff to avoid down time and have done so for about 10 years.
Rear mech, chain, chain ring, brakepads, wheel, BB, headset, pivot bearings, spare rim, front and rear tyres, some spokes and nipples (6 per wheel usually) a front and rear tyre, grips, cable inners and out, hydro hose, fork and rear shock service kit, shock bushes.
I am down a GX cassette at the moment, but both bikes were given new in Feb 2021 and I refuse to pay the outrageous prices that are currently about.
Posted : 22/12/2021 12:40 pm
I try to keep a spare of consumables
Only getting into mtb recently so don't have anything other than chainlinks and a tyre for the MTB. But chain cassette hanger etc for my road bike
I like my roadie running absolutely mint, so I change the chain fairly often
Posted : 22/12/2021 1:31 pm
yes, always have well stocked chains / pads etc.
in the last few years, kept stock of derailleurs to cover bikes,
tend to buy tyres when on offer, and i dont like paying postage so may as well get extras
Posted : 22/12/2021 2:01 pm
I have 6 bikes in our house all running 11sp drivetrains, with same size disc, Shimano brakes and Maxxis tyres. So, my spares box has about 3-5 sets of everything waiting to be fitted. As i fit something, i source another to put back in the box.
It does mean my spares box is worth over a grand however, so not a cheap endeavour.
It's paid off in the current supply chain drought though.
Posted : 22/12/2021 2:39 pm
I just checked stock with online sellers within China and Shimano Microspline 12spd cassettes are virtually gone everywhere. Some sellers still with some stock have upped the price 33%.
Sram XD cassettes are still available. No problem with hyperglide cassettes
Time to start stocking up compatible cassettes (Wuzei and TRW), or looking into swapping freehub, shifter and mech. Having 148mm MS freehub boost wheels is starting to become a problem!
Posted : 30/12/2021 4:39 am
Currently building a second bike up and using the exact same bits that are fitted to bike #1 for drivetrain and brakes.
After the hassle of getting a 12 speed shimano chain in the summer I'm keeping some spares in...
Posted : 30/12/2021 10:52 am
