i have a sticking rear piston on an xtr brake
is it easy enough to sort (and if so how) or is it a bike shop job?
Posted : 26/12/2009 3:36 pm
pump out the pistons a bit (not all the way!) by squeezing the lever with the rotor out
clean round the pistons with isopropyl alcohol on cotton bud and apply a small amount of lube (eg red rubber grease - I used RSP ultraslick as I know it doesnt eat rubber seals)
don't use mineral oil brake fluid to lube it as its sticky as hell and will get just sticky again as soon as you go off road
squeeze pistons back in
robert is your fathers brother etc
Posted : 26/12/2009 3:40 pm
gooner, pop yer bike round. Happy to have a faff with it. Should only take 10-20mins max including eating the jaffa cakes you bring with you ;-).
Posted : 26/12/2009 4:15 pm
