Stepping down a rev...
[Closed] Stepping down a revelation rlt ti 150mm to 120mm?
[#3145105]
Thinking of changing frame and would like to run 120mm but have a 2011 set of revs only had 2 rides out was wandering if they can be stepped down to 120mm.
Grateful for any help/opinions.
Posted : 13/09/2011 10:26 pm
Try asking PeterPoddy, he has a set of 2011 RLT forks on his C456 that he has opened up. He has done a fair bit of servicing of Rock shox forks in the past too.
I know they can be spaced down a bit but i don't know if they could be spaced down as much as 30mm
Posted : 13/09/2011 10:40 pm
cheers will do
Posted : 13/09/2011 10:42 pm
 wors
a mate asked loco this, he said it can be done but adds a bit of weight to the fork.
Posted : 13/09/2011 10:49 pm
I have stepped mine down to 130mm but i'm not sure if dropping further will work.
The ad for the fork states 130/140/150
Posted : 13/09/2011 10:53 pm
I wouldn't have thought it'd add much weight! as far as i am aware you are just adding plastic spacers. I guess it could be classed as a bit in comparison to air but in the overall scheme of things i would not think it would be much.
Posted : 13/09/2011 10:54 pm
cheers will give loco a call.
Posted : 13/09/2011 11:23 pm
fudge9202
you may want to take a look at this thread, mrblooby has RLT ti forks spaced at 120mm
http://www.singletrackworld.com/forum/topic/new-build-of-an-old-frame
Posted : 15/09/2011 10:14 pm
If they are 20mm maxle I'll swap a 120mm Reba Team 🙂
Posted : 16/09/2011 8:57 am
I was cheating a little, my revs are 150/120 dual position and I was running them at the lower position. Do plan to lower the max travel to 130 though.
Posted : 16/09/2011 9:31 am
