stans tubeless on m...
[Closed] stans tubeless on mavic 719s
Yellow tape on, rim strip on, valve core removed. Some stans goop inside.
Using a large co2 canister, I can get the tyres to briefly stay up, but they leak air and goop and go down very quickly. The tyres don't seem to actually click on properly and once they lose their air, they are coming away completely from the edge of the rim.
What am I missing?
Posted : 23/02/2013 3:57 pm
Tyre is a nobby nic tubeles ready pacestar
Posted : 23/02/2013 3:59 pm
Bollocks!! Got it to stay up, went in to get a cuppa.
Two mins later, heard a colossal bang, bugger had exploded and coated my garage in wheel jizz. Arse biscuits!
Tyre ruined too ๐Ÿ˜ก 50 psi was apparently too much ๐Ÿ˜† ๐Ÿ˜ณ
Posted : 23/02/2013 7:01 pm
Can't help but pictures please ๐Ÿ˜†
Posted : 23/02/2013 7:02 pm
Ha ha ha sorry I can't help but laugh at that image.
I have in and got 18bikes to do mine.
Posted : 23/02/2013 7:08 pm
parkesie - Member
Not sure where that girl came from
Posted : 23/02/2013 7:12 pm
I had exactly the same experiance with a RaRa, pain in the arse to get the bead seated, then the bead failed and filled the garage with spaff. Luckily for me, it was on a mates bike at the time and it was his garage, saving me the clean-up ๐Ÿ™‚
Stans no longer recommend schwalbe tyres due to the high number of bead failures. I'd try again with a Maxxis tyre.
Posted : 23/02/2013 7:15 pm
I just put some snakeskin NN's onto stans crest rims. Tyres went on without levers and inflated with a track pump. It does say on the rim not to exceed 45psi though. They've been at 30psi for 3 days now. All seems good so far.
Posted : 23/02/2013 8:47 pm
Be wary of using CO2 with the jizz already in the tyre!
It can, in my experience, cause it to set - once the tyre has popped onto the rim then insert it using an injector through the valve stem!
Posted : 23/02/2013 8:50 pm
Where does it say that stans no longer recommend schwalbe tyres?
Posted : 23/02/2013 9:33 pm
I think Stans advised against Schwalbe tubeless for a time but are now saying they're ok again. FWIW I have the same rims and have set up Specilaized and Bontrager tyres without any issue - not tried Schwalbe.
Posted : 23/02/2013 9:55 pm
It would appear that all 29'er tyres are now suitable according to this -> http://www.notubes.com/recommendedtires.aspx
Posted : 23/02/2013 10:24 pm
Compatible Non Tubeless* tires:
29er Tires: All
but
Not Recommend Tires
WTB TCS and UST 29 inch tires are too tight for Stan's Notubes rims and NoTubes licensed rims such as Sun Ringle Black Flag.
Unless they have tested "ALL" tires then I'm guessing there are still some odd balls out there.
Posted : 23/02/2013 10:27 pm
It was on their website last summer, shortly after I'd bought a Nobby Nic and Racing Ralph ๐Ÿ‘ฟ , just had a look round and can't find it anymore. Never had a problem on my flows, just the 719.
Posted : 23/02/2013 10:56 pm
I've used 719s/Stans rim strips with Spesh 2bliss Eskars and also Maxxis Highroller & Minion (both wire & folding), no problems with any of them.
Posted : 23/02/2013 11:08 pm
Never had a problem with Evo NNs on my Rovals.. Back took a bit of sloshing to get it airtight and the valves a wee bugger but apart from that its all good in the hood.,
Posted : 23/02/2013 11:21 pm
Simon - Member
Does the tyre hook/click into the bead? Or is it just air pressure that keeps it on?
If you let all the air out, would you be able to reinflate without a compressor?
What's the secret? Extra layers of tape?
Posted : 24/02/2013 10:15 am
