Stan's sealant...
[Closed] Stan's sealant - lumpy?
First time tubeless setting up ...Fresh bottle of Stan's sealant and after a very good shake, removed the foil seal, injecting in through the valve it clogs the syringe with large 2cm long lumps of congealed sealant - I am assuming this isn't normal?
think I need to send this back to whence it came :o(
Posted : 20/02/2015 9:39 pm
Yes
Never had stans clog up a 50ml syringe that has a reasonable bore . I set the beads then deflate and de core , whizz in 60ml of stans and re-core.
Does need a good shake but never had worms, worms appear inside your tyre after a few months.
Posted : 20/02/2015 10:02 pm
Could of been stored in sub zero conditions.
Posted : 20/02/2015 10:19 pm
Did you remove the valve core?
Posted : 20/02/2015 10:37 pm
Yes removed the core ๐Ÿ˜†
Posted : 20/02/2015 10:40 pm
I'm about to go tubeless for the 1st time (not counting a brief dalliance with ghetto tubeless) and have been reading various reviews on the different sealants and have decided to have a go with 'Oko magic milk'.
http://www.oko.com/oko_magic_milk_for_bikes.html.
The few reviews of it seem to rate it better than stans,with a longer working life hence my decision to plump for it.
Also OKO were the originators of tyre sealant(presumably in the automotive industry) so should hopefully know a thing or two.
Posted : 21/02/2015 4:30 pm
