Standard Nobby Nic&...
[Closed] Standard Nobby Nic's And ZTR Rims Tubeless Woes
Im trying to get some standard NN's set up tubeless on ZTR flow rims. I've done the front fine, but the rear seems to be 'porous' and the sealant wont stop air from slowly leaking out from near to the bead.
Has anyone else had this issue, and is there an easy way to fix it?
James
Posted : 18/07/2010 6:31 pm
Put more sealant in until it seals โ“
Posted : 18/07/2010 6:37 pm
as long as they inflate and then you get some seepage from the porous bits it's not a major issue. Do the normal Stans shaky dance and then leave the wheel horizontal over a bucket/box etc... leave for about 15 mins bang some more air in do the shaky shaky routine again and leave horizontal with the other side facing up. Always sorts it for me with porous tyres, I've even got speedking supersonics to play and they've got more holes in Rab C Nesbits vest.
Posted : 18/07/2010 6:47 pm
Stans shaky shaky dance???
Posted : 18/07/2010 7:01 pm
Even I know that!
Still haven't tried mine yet.
Posted : 18/07/2010 7:03 pm
My Nic went up no problem with no leaks. Had 2 ralphs though - 1 was fine, the other leaked constantly from the join between the sidewall and tread. Kept adding fluid and eventually it sorted itself.
Posted : 18/07/2010 11:29 pm
 P20
Had no problems with mine. The last one was the easiest tyre I've put on. Was almost disappointed that it inflated 1st time. I agree that the shaky thing works on pourous tyres.
Posted : 19/07/2010 1:13 am
TBH if you have major leaks sealed just go out and ride it - works for me even if after the first couple of rides you have to add a little more air in ๐Ÿ™‚
Posted : 19/07/2010 8:11 am
shaking it about and adding an extra red cup of sealant did the trick ๐Ÿ˜€ cheers guys
Id always just spun the wheel, but thinking about it this would force the sealant outwards to the tread area of the tyre rather than giving the whole surface a good coating, so +1 for stans dance
Posted : 19/07/2010 10:03 am
