This is the first time shopping for jockey wheels, i'm struggling finding compatible ones.
The sram option-
http://www.chainreactioncycles.com/Models.aspx?ModelID=49729
But are expensive and haven't lasted long.
What are the compatibility issues i see listed on a lot of jockeys with sram x7/x9 2010?
I just want some cheap jockey wheels that work ok.
I got some sealed bearing, coloured alloy jockeys off ebay for £11 last month, great value and quality too.
BBB rollerboys from dotbike, was the type/place I got mine from, last time I needed some
100mphplus - any chance of linking me to said jockey wheels? Have you installed them yet? Working well?
TBH I very much doubt what 100mph+ got will not be X7/9 compatible. Check out KCNC jockey wheels.. lovely looking but not Sram compatible
The BBB ones are x7 compatible and have sealed bearings. Can't remember the model number, and they can be a bit elusive. If you get some they work well.
I couldn't source jockey wheels for my '10 X9, however I waltzed into my nearest Evans who found me a pair of Shimano nine speed Tacx jockey wheels which came with a plastic sprue carrying a multitude of adaptors for less than £19.
And guess what...they fit just fine.
But they're not coloured metal and 😯
Link to Dotbike for BBB Jockeys.
I have the Shimano flavour 10T and 11T versions and am very impressed.
Open a seal and fill each cartridge bearing with grease before fitting, then ride and ride.
PaulD
Are both jockey wheels the same on a sram 2010 9 spd x7 ? Have seen a pair of ceramic bearing wheels on ebay ,which are marked as upper and lower,but the coloured alloy jockeys on e bay appear to be of one size ???
