SRAM X1 1x11 - Chai...
[Closed] SRAM X1 1x11 - Chain too wide?
Hi all,
I'm looking for some advice please...
New bike with 1x11 setup. The chain and cassette are both X1 (XG1180) so they should be compatible. Something I've noticed though is that the chain seems a tiny bit too wide and as it engages on the sprocket - it also slightly rubs on the neighbouring sprocket's teeth.
You can only tell when the bike is in the stand and you're looking for it. You don't really notice it when pedalling.
Am I nitpicking? Is this normal?
Posted : 10/05/2015 8:56 am
 gee
What's the code stamped on the chain? Or perhaps gears not set up correctly or hanger bent.
Posted : 10/05/2015 9:27 am
Will find out exact chain code later... But i think its something like "X1... "
All gear changes are smooth and H & L screws are set right. The B tension screw has set the topmost jockey wheel to be about 2cm from the bottom of the 42t sprocket.
Posted : 10/05/2015 10:05 am
Sounds like it's a setup thing. Have Xx1 on my bike and it rubs slightly on the next sprocket if the cable tension is not perfect. You do know the the low screw setting is not set up in the middle of the lower jockey wheel I presume?
Edit: B screw gap sounds too big, seem to remember mine is around 13 mm. Think the range is 12 to 15mm. Or see here
http://mytwowheelers.blogspot.co.uk/2014/10/how-to-adjust-sram-xx1-rear-derailleur.html
Posted : 10/05/2015 10:29 am
