Sram wide t type cr...
Sram wide t type crankset with 52mm chain line
I wondewr if anyone can shed a little light on this for me please . Are the newer T type cranksets compatible with the older Eagle groupsets .ย  I know they are 55 mm chainline where as boost is nortmally 52mmย  .. I like the intergrated bash rings and cranksets but im not a fan of the direct frame mounted rear mech and happy to say bye bye to a hanger and use my older Eagle stuff .ย  Long and short is anyone using them with differnt chainrings or spacers ?
Posted : 16/04/2024 4:56 pm
cranks would be compatible with a different chainring (either 3mm to run 55mm CL or 6mm for 52) but good luck finding a non-T-Type 8 bolt ring.
Posted : 16/04/2024 4:59 pm
I believe the T-Type chainrings are backwards compatible with normal Eagle stuff. The compatibility chart from SRAM seems to confirm it.
Posted : 16/04/2024 5:39 pm
Yep the chain rings mesh as normal, its been tested .
Posted : 17/04/2024 9:57 am
55mm chainline seems to work better with everything for me, but given the chainstay length, 3mm isn't huge. All seems quite irrelevant in the grand scheme of things.
Posted : 17/04/2024 12:12 pm
I did read with the Dub wide axle Id need a 3mm spacer none drive side and 7.5 drive sideย  ย , at the moment im running 4mm on the drive.ย  ย might look all a little odd
Posted : 17/04/2024 4:40 pm
