SRAM Red eTap Wifli...
[Closed] SRAM Red eTap Wifli frame compatibility...
Can anyone advise is Red eTap compatible with 'mechanical' framesets? I currently run mechanical Ultegra and fancy going over to electronic.
Posted : 13/02/2019 1:27 pm
Given the lack of cables I’d have thought there would be absolutely zero compatibility issues.
Posted : 13/02/2019 1:29 pm
 beej
I've got it on two "mechanical" framesets. The only difference is that I have unused cable guides on one, and unused internal routing on the other. eTap doesn't need to run cables or store batteries or junction boxes.
Posted : 13/02/2019 2:24 pm
What issues do you forsee?
Posted : 13/02/2019 2:40 pm
My main worry was around the front mech. I gather, and i could be wrong here, that Ultegra Di2 has a different attachment method to mechanical...which is why i see electronic specific frames. I presume the eTap front mech fits the fitting on a mechanical groupset frame (or adaptors must be available?).
Posted : 13/02/2019 3:08 pm
that’s nothing to do with wireless or mechanical though. I think you can get them with different mounting options (band/braze on etc)
Posted : 13/02/2019 3:16 pm
 aP
Having just put eTap on my 2005 Merlin CR6/4 I can confirm that it fits just fine, but you may need to get a SRAM band-on front mech fitting as the Shimano one I've had on for 13 years wasn't compatible.
Posted : 13/02/2019 5:38 pm
