Sram rear mech, wea...
[Closed] Sram rear mech, weak spring?
My Sram GX rear mech has real trouble changing down onto lowest two cogs (1x11 setup).
I spent hours tweaking everything to no avail - and it's now been suggested by LBS it could be a problem with the spring in the mech.
That's a new one on me, but has anyone else had the same? Any way to fix?
Posted : 11/04/2017 2:29 pm
The cable routing isnt fouling the jockey arm is it? Seen that a few times.
Posted : 11/04/2017 2:30 pm
I'll have a look cheers Ben, but it's been the same on two separate frames so probably not.
Posted : 11/04/2017 2:35 pm
Its the mech set up that causes it not the frame - its where the cable runs around the little plastic loop that guides it towards the pinch bolt. That can foul the arm in 10 & 11 if the combo of chain length and b tension isnt right, preventing you from getting those two smallest cogs (if I am understanding your post right)... and is generally caused by the get the shortest chain you can to work approach to chain sizing - SRAM generally prefers the longest chain you can get away with, or at least one longer than the shortest that would not tear itself to bits anyway.
Posted : 11/04/2017 2:49 pm
Very useful thanks, chain is on short side. Will investigate.
Posted : 11/04/2017 2:57 pm
I had this on a SRAM Rival 1x11 - I spent ages doing all sorts of adjustments per the usual instructions.
Gave up and took to bikeshop - they identified too short and tight a loop at the back into the mech. Replaced cable with a longer slacker loop, and shifting was sorted.
Didn't stop the cable-end popping out at the shifter end though.
I think the whole system is much more friction-sensitive than good ol' 3x9 🙂
Posted : 11/04/2017 3:06 pm
SRAM- basically you are their R & D department, and if it don't work they might just give you the exact same bit again on warranty and that won't work either.
Posted : 11/04/2017 4:27 pm
Not entirely fair.
SRAM stuff is generally differently engineered to Shimano and suffers when installed by people that don't read the instructions because they know how to fit a mech, bb, crank whatever.
Possibly they sometimes make things more finicky than they need to be, but without someone pushing the industry forward we'd be stuck with whatever Shimano wanted to give us and their fixed product rotation.
Posted : 11/04/2017 5:59 pm
just upgrade to sram eagle, then all you have to worry about is replacing the £80 jockey wheels and inner plate every few weeks when the thread for the top jockey wheel sheers off.
Posted : 12/04/2017 7:57 am
The spring thing definitely was an issue for older SRAM (i'm still using some old 9-speed sram and the bike has to be parked in the highest gear, otherwise it won't select it next time I ride it) So it might be just that they're presuming "used to happen so that's what it'll be"
Posted : 12/04/2017 11:10 am
