SRAM Power Link 10 ...
[Closed] SRAM Power Link 10 speed
Been using these fine on a 9sp chain for years.
Now I'm finding on my 10sp chain I cannot get the thing undone. Anyone else have this problem or am I weak and feeble. Any tips gratefully received.
Matt
Posted : 09/09/2012 10:19 pm
The 10 speed ones are not meant to be undone. They are called PowerLOCK, not PowerLINK. I believe that some folk are managing to do it though - some with the help of a Park Tool of some sort.
However, I've found that a 9-speed one works just as well on a 10 speed chain.
Posted : 09/09/2012 10:20 pm
They're single-use on 10 speed. Not possible to undo them.
Posted : 09/09/2012 10:21 pm
Get ome KMC ones instead.
Posted : 09/09/2012 10:26 pm
Superstar sell a missing-link remover which does the job easily- though, I've not tried to use mine since, just refit it to make sure it was possible then dropped it in the spares box.
KMC ones are reusable.
Posted : 09/09/2012 10:27 pm
Well that explains everything. What were SRAM thinking. The power link was perfectly fine as it was. Why change it?
Matt
Posted : 09/09/2012 11:39 pm
never, ever had a 9s powerlink fail (only normal links). solving a problem that didn't exist, or getting you to buy new chains or something? SRAM lost a customer here. not that i ever remove chains for cleaning anyway 😀
Posted : 09/09/2012 11:46 pm
How much! one KMC chain link £8....
didn't think going 10 speed and 29er would cost this much!
Posted : 10/09/2012 6:48 am
Try the YBN links too.
Posted : 10/09/2012 8:27 am
try decatholon, £3.99 for 2 made buy KMC
Posted : 10/09/2012 8:29 am
You need a pair of these to un-do them;-
http://www.chainreactioncycles.com/SearchResults.aspx?Search=powerlink+pliers
I have re-used a 10 speed link and no problem so far!
They are a bitch to put on too, you either need another pair of pliers like these yellow ones;-
http://www.chainreactioncycles.com/Models.aspx?ModelID=56350
....or you have to fit the link so it's just 'biting', run the link round the cassette so it's on the 'pulling' side and stand on the pedals, the force will lock it.
Posted : 10/09/2012 11:27 am
Can anyone else confirm a 9 speed link will work with a 10 speed chain without any fuss?
Posted : 10/09/2012 11:29 am
I does indeed work OK
Posted : 10/09/2012 11:30 am
A trick to undo them is to use some internal shifter cable tread it through the link and twist with some std pliers and it will undo.
 Leku
This explains a lot (of swearing) the other night when I tried to undo one.
( off to get some KMC ones...)
Posted : 10/09/2012 12:25 pm
I used a 9spd one on my 10spd bike in an emergency in the alps and it ended up giving way on a climb. The 9 spd ones are slightly wider than the 10spd ones and I think this small amount of lateral play introduces a weak spot. I swapped it out for a 10spd KMC one and it has been fine ever since so for the sake of a few quid, I wouldn't risk it.
Posted : 10/09/2012 12:41 pm
[quote=hughjayteens ]The 9 spd ones are slightly wider than the 10spd ones
By 0.6mm IIRC?
Posted : 10/09/2012 12:45 pm
druidh - Member
hughjayteens » The 9 spd ones are slightly wider than the 10spd ones
By 0.6mm IIRC?
Quite possibly but if you try it you see the play quite easily and having had a chain snap on me when flat out uphill and ending up on my back having gone OTB, I wouldn't risk it!
Posted : 10/09/2012 1:00 pm
