I have an unused Sram x7 2x front shifter. I want it to operate a Shimano direct mount front mech.
I will be using the inner two rings if a 10sp triple chainset.
Will this work? I have yet to buy the front mech, does it have to be a 3x, or will 2x work?
thanks
Posted : 18/05/2019 3:49 pm
The pull ratio of front mechs SRAM / Shimano is usually the same, so yes, either shifter would work. The chainring gaps are also the same 2x and 3x so again you should be ok to use a 2x shifter to move between two of the three rings. Mechs are shaped to match the rings and tooth capacity so you'd be best using a 3x but a 2x would probably work anyway.
Posted : 18/05/2019 4:49 pm
Have always used a SRAM shifter with a Shimano front mech. Never even thought it might not work.
Posted : 18/05/2019 5:00 pm
thats ace! thank you
Posted : 18/05/2019 5:08 pm
