I folks.ย Can you convert a non-boost xx1 eagle crankset by using the boost oval ring like this:
https://absoluteblack.cc/sram-oval-boost-direct-mount-traction-chainring/
Just want to check if anyone has tried it
Oli
Posted : 04/12/2018 2:08 pm
yeah should just be the chainring on the direct mount set ups. Someone please correct me if wrong but pretty sure it's 6mm offset for non-boost and 3mm for boost.
You can also get spiders from Sram or NSB that will let you use a bolt up chain ring.
Posted : 04/12/2018 2:14 pm
sounds right to me andy
Posted : 04/12/2018 5:37 pm
Yes that will work .
Posted : 04/12/2018 7:58 pm
