SRAM bleed port plu...
[Closed] SRAM bleed port plugs (Code/Guide)
Design of these brakes and the 'bleeding edge' port means bleeding is really clean now....but the port is just covered by a push in rubber bung. That falls out - and then you risk pushing dirt into your brakes.
Any suggestions on where to get a spare (or what to use other than a bit of tape over it?). SRAM only seem to sell it as part of a full seal kit.
Posted : 18/01/2022 5:26 pm
i discovered i'd lost one recently and that you can't get replacements without buying the full seal kit. ended up filling the hole with a bit of those small ear plugs and covered it with a small bit of black tape, still there a few rides later.
it has taken me 3 and a half years to loose it.
Posted : 18/01/2022 8:52 pm
Try a search for blanking grommets, it may turn up something suitable.
Posted : 19/01/2022 4:58 pm
