Squealing brakes
[Closed] Squealing brakes
8 Users
XT discs, really loud!! just started in the last few weeks
Pads look pretty worn but not worn out will probably replace anyway, anything else to consider?
Pat
Posted : 26/01/2016 4:41 pm
Contaminated disk.
Loose bolts on the mountings.
Clean the rotor, sling in some new pads and see what happens!
Posted : 26/01/2016 4:45 pm
when you're out riding stuff some wet mud into the caliper.
it works, trust me.
Posted : 26/01/2016 4:51 pm
If the brakes judder and make a horrible squeal as you roll to a stop, they are contaminated with oil. Clean the disc with IPA or glass cleaner and put the pads in the dishhwasher. Then look for the leak.
Posted : 26/01/2016 5:01 pm
It stops well, neither lever is spongy - but both discs are as equally bad in terms of noise.
will give the rotors a clean, i assume by IPA you don't mean a pint of Greene King?
Posted : 26/01/2016 5:19 pm
Muc-off disc cleaner on discs and pads. Repeat every few rides
Posted : 26/01/2016 11:49 pm
If all is performing well, and it's simply noise that's the issue, find a nice long bit of gentle downward tarmac, get some speed up and burn them in.
Posted : 27/01/2016 1:57 am
Def not Greene King it's only good for swilling drains out.
Posted : 27/01/2016 3:06 am
My XT brakes squeal very loudly in the wet, but are fine in the dry. Any ideas?
Posted : 27/01/2016 9:36 am
tighten all the bolts up, stuff mud in the caliper.
Posted : 27/01/2016 10:00 am
