Squeaky Blur LT1; p...
[Closed] Squeaky Blur LT1; part 2
I posted on here a while back about the squeak. Since then I tried changing bearings and pivots and axles, plus shock bushings as well. I also greased bb, headset and all bolts on the bike. Also ensured all pivots tightened.
It is still SQUEAKING !!!! And it's the same squeak as it made before I did all the above.
Any other suggestions? It only sounds when the suspension is active, when pedalling or not.
Could it be the bike shop did not put any/enough loctite on bearings?
Posted : 11/09/2010 7:30 pm
If loctite hadn't been use there would be play in the linkages I assume you let this set properly before using the bicycle! Have you tried different pedals? Squeaks on bikes are awkward it's a process of elimination to get rid if it if you can't locAte it, just go around the whole bike, clean grease all relevant parts, try different wheels in the bike to eliminate it from being them you'll soon sort it.
Posted : 11/09/2010 8:56 pm
