Square Taper axle l...
[Closed] Square Taper axle length...
5 Users
What axle length would i need for a 2007 Orange 5 frame?
I want to fit Middleburn RS7 cranks but i'm relatively new to MTB and know nothing about square taper! The multitude of lengths is rather confusing.
I intend running a 24/36/Bashquard set-up, if thats important?
Posted : 19/03/2009 8:13 pm
I am running exactly this on mine...
73-113mm, anything shorter and the cranks wont go on, anything longer and you'll have a hideous chainline.
Posted : 19/03/2009 8:16 pm
most modern (non DH) mountain bike frames are designed around a 48mm chainline. Middleburn cranks produce a 48mm chainline with a 113mm BBaxle for both square taper and ISIS.
Using a double and bash shouldnt really make much difference, stick to a 48mm chainline. If you try to bugger around re-centering the chainset on the cassette by moving it outwards (with a longer BB axle) you will probably start having problems with the front mech.
Posted : 19/03/2009 8:17 pm
113mm is right according to the middleburn website
Posted : 19/03/2009 8:18 pm
Splash out and get a decent one..... I run a Royce Ti in both bikes and they are brill. You can give the cranks a firm tap (without a chain on) and they will spin 6-7 full revs.
Posted : 19/03/2009 8:26 pm
thats my next treat, a Royce Ti for my middleburns.
Posted : 19/03/2009 8:33 pm
Thanks quys, just the advice i needed.
Posted : 19/03/2009 8:36 pm
