Spring Calculators?
[Closed] Spring Calculators?
Is it just me or do the online spring calculators sound a bit light? Im 12stone.4 full kitted up and I've always used a 450 or 400 for downhill but checking online it reckons I need a 350, anyone else found similar and tried lighter?
Posted : 05/07/2010 12:47 pm
 LoCo
They vary from company to company, what is the stroke of the shock and rear wheel travel, and model of shock?
Posted : 05/07/2010 12:49 pm
LoCo probably knows more than me but it depends on the damper as well as the bike, if its more compression damping and less rebound damping it will need a softer spring, this was the trend in motorcross for a very long while (softest spring you could get away with and as much damping as possible to keep the bike level once it gets moving accross rough ground).
Posted : 05/07/2010 12:53 pm
dhx5, 3.25 spring on it but really its a 3 its just how fox list them, 8inches on a vpp (socom)
 LoCo
350 lbs/in would be the ideal weight for you, giving the correct sag.
Other setting [b]suggestions[/b] from experience with these shocks are:
Bottom out fully open ( full out)
150psi in boost chamber (on the piggy back)
Hope this helps, any further queries you can mail me in my profile.
Simon
Posted : 05/07/2010 1:15 pm
Rider in "has personal preference that deviates slightly from someone's rules" shocker!
Posted : 05/07/2010 1:23 pm
Thanks Simon appreciated ๐Ÿ™‚
Posted : 05/07/2010 1:40 pm
