Specific tubeless s...
[Closed] Specific tubeless set up questions (Shimano XT M788)
[#5275589]
I have a Shimano XT M788 Rear Wheel. It is so hard to get tyres on and off that I would like to try going tubeless.
Questions:
1. If I buy a Nobby Nic 2.4 UST tubeless tyre, do I need to buy sealant as well?
2. I have a good condition non-UST Kenda Nevegal 2.35. If I bought sealant, would that work reasonably tubeless with my XT M788 wheel?
Thanks for any advice.
Posted : 24/06/2013 8:01 pm
Shimano xt wheels are UST, so any UST tire should seal up without sealant, but I use it anyway for extra protection.
I've also used specialized tubeless ready tires with sealant, but haven't tried normal tires yet.
Posted : 24/06/2013 8:13 pm
I have XT 29er tubeless wheels with Conti non-tubeless tyres. They went straight on and inflated but the sidewalls are porous. So a splash of sealant and all is good.
Posted : 24/06/2013 9:25 pm
Whatever tyre you run you should defo use some sealant. The whole point of tubeless is that the sealant catches any punctures. You don't need much. Stans is V good. Other options available.
Tubeless without sealant is kinda pointless.
Edit. if you get a puncture you have to stick a tube in. With sealant you don't.
Posted : 24/06/2013 9:34 pm
Thanks all.
Turning out to be an expensive wheel replacement!
Posted : 24/06/2013 11:07 pm
