Specialized Phenom ...
[Closed] Specialized Phenom saddle problem
6 Users
I have two of these and both have gone; 1 after 4 months of light use and the other after less than a year riding - the rails are loose where they fix into the back of the saddle and there is a perpetual clicking / cracking sound whilst riding.
Has anyone had similar problems and any solutions suggested?
Posted : 02/01/2019 10:17 pm
Get a charge spoon or a madison flux.
Posted : 02/01/2019 10:34 pm
I haven’t had any issues with mine in two years of riding my HT at trail centres, local trails and multi day XC touring. Prior to that I had a Charge spoon - which was the most uncomfortable saddle I had used. A things to consider: have you got the correct width Phenom? Have you got the pro or standard? Does the phenom have a recommended rider weight range and are you outside of that? Or maybe just the way it’s fitted on your seat post?
Posted : 02/01/2019 11:11 pm
Yep, mine do the same.
I've also had a rail pop out of the end hole. No matter how hard I tried, it wouldn't go back in.
Mine were about 2 yrs old when they started going. I just use a different brand now.
Posted : 03/01/2019 12:30 am
Have you tried to warranty them? Specialized are very good in that department
Posted : 03/01/2019 8:38 am
Have two, both have around 3000miles on them, no issues. I'd send them back to the shop for them to look at, they arn't cheap and should be lasting a lot longer than that!
Posted : 03/01/2019 9:02 am
Thank you all. Will try specialized directly. Then go for another brand if not success. 🙂
Posted : 04/01/2019 2:33 pm
Got a warranty replacement saddle. Many thanks to Graham at Pedal Heaven in Fleet for organising this for me.
Posted : 18/01/2019 2:50 pm
