Specialized 2Bliss ...
Specialized 2Bliss rim strip - any experience ?
[#13535694]
This looks a lot less faff than the usual sticky rim tapes, but does it work as well? Any experience, before I land myself with a world of mess and disappointment ?
Posted : 26/05/2026 2:40 pm
Yes, used them on a Camber and a Levo and have worked perfectly. Better than messing with sticky tape!
Posted : 26/05/2026 2:44 pm
Have got them on most of our rims. Been using them for years and never had a problem.  So easy to re use after spoke replacements
Posted : 26/05/2026 2:52 pm
Sold 🙂
Posted : 26/05/2026 2:59 pm
Have had the Specialized ones and found them good, but would recommend the Newmen ones also, they work really well.
https://www.bike-discount.de/en/newmen-tubeless-strips-29-rim-tape-set
Posted : 26/05/2026 3:13 pm
 LAT
Better than tape in my experience.
Posted : 26/05/2026 8:37 pm
Been using them for years across many bikes, have a draw full of em, would recommend!
Posted : 26/05/2026 9:58 pm
As above been using them for years with no issues, I'm surprised they haven't taken off and been produced by more companies
Posted : 27/05/2026 5:19 am
Are they harder to install?
I really like the idea of not faffing with tape - & they are cheap too... I see no downsides?
Posted : 27/05/2026 8:35 am
Just stretch them onto the rim - can have a slight faff in that you have to make sure they sit evenly, so you might need to lift and stretch it anywhere it's not centred/even - but miles less faff than tape.
Posted : 27/05/2026 8:47 am
They are generally a little thicker than tape, so might make a really tight tyre/rim combo a bit trickier. Bontrager do rim strips that make tight tyre/rim combinations literally impossible, do avoid those
Posted : 27/05/2026 8:48 am
Posted by: oikeith
Chester?
Posted : 27/05/2026 11:13 am
So all really positive feedback and I've heard the same elsewhere but they seem to be some kind of secret. It's one of those really odd things that rarely comes up. I guess the answer is to get TJ on them, the putoline prophet, and then at least we'll get to hear the message preached at every opportunity 🙂
I think I'll give them a go on my 650b gravel wheels if I can get the right width
Posted : 27/05/2026 11:33 am
tjagain reacted
 PJay
I'm sold too. I have a slow puncture on my rear wheel I can't track down and wondered whether the tape might be damaged.
Do you just buy for the correct wheel circumference or do I need to match the width? My Hope XC wheels are quite narrow (19.5mm internally I think) so I'm not sure if this will pose a problem.
-- Edit --
It looks like 23mm is the narrowest width, I imagine that this will be too wide and I'm screwed. Are there other brands in narrower widths available?
Posted : 27/05/2026 11:50 am
I use 32mm ones for 30mm Newmen wheels, they narrow a bit as they stretch
The Specialized ones don't shrink in the same way, IIRC, they're a less rubbery material. Might be on the wide side.
Posted : 27/05/2026 3:45 pm
 PJay
I found some Joe's Flats ones. 19-25mm seemed a bit much to cram in so I'be ordered 17-,19,mm 🤞
They'll be kept in reserve in case my slow puncture worsens or the tape fails. Worst case I have spare tape.
Posted : 27/05/2026 5:20 pm
As above used for years with a no issues at all.
I tried stans when I needed a quick fix and couldn't get a 2bliss. No idea why anyone would use tape.
Posted : 27/05/2026 5:37 pm
