Spacing Rear Dropou...
[Closed] Spacing Rear Dropouts for Transport of frame
10 Users
Anyone have a good way to do this? Concerned my frame will get bent when transported without the rear wheel in.
J
Posted : 13/11/2010 11:55 pm
I used a bit of 22 mm copper pipe recently - its what I had to hand, Kept in place with cable ties.
I think threaded bar ( available fronm B&Q) is the best stuff I have used. 4 nuts and washers so one each side of each dropout
Posted : 13/11/2010 11:57 pm
+1 for the copper pipe. I use my skewers to hold them in place.
Posted : 14/11/2010 8:48 am
Frame I was sent had a small (135mm-ish wide) piece of wood between the dropouts, secured with some self tapping screws through the dropouts. Simple but effective
Posted : 14/11/2010 8:51 am
i think my frame came with a plastic drop out spacery thing. maybe you could beg one from your lbs?
get an old hub and use that if its a built bike minus the wheels leave an old cassette on to carry the chain and the paint wont get knackered.
Posted : 14/11/2010 8:53 am
Good ol' friendly LBS, they usually come in new frames, so worth asking there.
Posted : 14/11/2010 8:58 am
I found that an old ODI lock-on grip + 5mm stem spacer did the trick - lighter than an old hub too.
Posted : 14/11/2010 9:05 am
 Andy
Roll of corrugated cardboard, bit of packing tape and 4 cable ties here works fine.
Edit: If its a frame I'm selling. For flying I use a QR axle and the rear QR.
Posted : 14/11/2010 9:24 am
or you can spend loads on [url= http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=334 ]these[/url], which at 14.99 is ok...
Posted : 14/11/2010 9:25 am
 Andy
Toys19; yup added the plastic brake shims on a bit of elastic too. Leave the front and rear in my bike bag, when not used. 😀
Posted : 14/11/2010 9:28 am
thanks guys, will look into a few of those ideas!
Posted : 14/11/2010 9:56 am
