Some advice & t...
[Closed] Some advice & thoughts on SS gearing please
Morning All
I currently run my SS 32:16 which I find adequate for most of my rising off road. I'm currently using the SS mainly on the road now for my commute which is 11 miles with 4 uphill sections, not crazy steep but long. The 32:16 is ok for the uphills but I find I spin like a fool on the flats in between; good for interval training but can be quite frustrating.
I think I need to change my ratio but dont know wheteher to change the cog on the back to a 15 or look at a bigger ring up front, maybe a 34? Bigger? I appreciate any change will make the uphills harder but should make it easier to get a better rythem going on the flats.
What say those who clearly know better then me?
Posted : 18/07/2012 10:11 pm
Rear is easier than front to swap around.
Posted : 18/07/2012 10:14 pm
I normally ride in 36-14 backwards and forwards to work on my hardtail. It's not SS though I just don't change gear. Never spin out and I like getting out the saddle for the one real hill either way.
I haven't ridden in almost 12 weeks though because of a broken arm. I should be able to start commuting again next Monday but I suspect it might take me a while to get back to using that ratio though. ๐Ÿ˜•
Posted : 18/07/2012 10:22 pm
I'd thought that it might be quicker to swap the rear out so maybe getting a 15 is the way to go?
Posted : 18/07/2012 10:24 pm
I reckon you'll always have a challenge finding something that's right on AND off road. I ride 32:16 off road and i find that perfect. I took up SSing last year and bought a few alternative rear cogs but have never once considered moving away from 32:16 for off road. Very little to lose from trialling a 15 or 14 on the back but i suspect you may find those challenging off road. I can dig out my surplus unused cogs and check the sizes if you're interested in having them off me at cost?
Posted : 18/07/2012 10:39 pm
If you were to try 32:15T is not goling to help much on the flats but will hurt a bit more on the hills.
32:14T sounds better and all you will have to do is introduce a half link to maintain your curent tensioner position if you use one.
A taller tyre will have the same effect as well. you would suprised now much of a difference rolling diamter makes.
You could also try a 34:14T and a narrow low profile tyre to reduce roilling diamter to make the change less severe.
Posted : 18/07/2012 10:50 pm
You could try a few gears on there... This is just the situation they were invented for. ๐Ÿ™‚
Posted : 19/07/2012 7:58 am
๐Ÿ’ก dinglespeed
Posted : 19/07/2012 8:07 am
I plan to keep the 32:16 for when using it off road its more for the road side I was looking at changing the ratio.
My tyres are City Jet 1.5's which arent the tallest but are very smooth roling.
Posted : 19/07/2012 10:10 am
