I've looked at the drawing on the hope website but its confused me, which part/parts am i missing from this hope headset? Is that the right race? it has a 1mm or so gap when to press it next to the bottom cup assembley.
Top cup- Am i missing a seal or something?
[img]
[/img]
Bottom cup- Is that the right race?
[img]
[/img]
Thanks a lot
No, its the old one.
No-one?
looking at mine (still fitted to a frame), you only missing the o-ring that sits under the top fitting (not the cap), it might be under the inside of it.
As per Foxy, the replacement crown race I got for mine is split and has two o-rings as part of it.
(Surprisingly this piccy has no split but is from CRC Hope crown race page but does show the outer o-ring)
[img]
[/img]
wait a minute, ive been a complete numpty, the top bits sorted now, you use the circular sealed bit on the top that i tought went on the bottom, so i may be missing somthing from the bottom, or does the race go straight onto the bearing?
It goes straight onto the bearing, hense the requirment to have the crown race to have o-rings, as it's the final seal @ the bottom
