Snapped spoke tubel...
[Closed] Snapped spoke tubeless tyre lost pressure
is this normal? I'd have thought the tape should heve sealed up the valve hole, and shouldn't have been affected by the nipple coming loose?
Posted : 18/03/2020 10:35 am
Nah, had that happen in finale. You'll find the nipple has pushed the rim tape up, sealant gets under it, then the tape doesn't stick and air gets out. Bloody annoying.
Posted : 18/03/2020 10:55 am
cheers - so i'll need to re-tape it then I guess?
put it on the lockdown job list!
Posted : 18/03/2020 11:01 am
Sealant gets flung to the outside, away from the tape. Sealant doesn't stick well to the tape either.
When I raced the mega a few years ago, I solder tied the spokes, in the event of a spoke coming loose/failing it wont flap around, either puncturing the rim tape or getting mangled in the wheel.
null
Posted : 18/03/2020 11:15 am
Weird, how much force is the nipple/broken portion of spoke under that it can push up the tubeless tape which is also being held in place by the tyre? Is it the effect of the spoke snapping and the nipple firing up into the tape like a little bullet?
Posted : 18/03/2020 11:20 am
Yes. There's typically around 100kgf on that spoke which all let's go instantly. Getting through a bit of flimsy tape is easy.
My personal preference is for UST type rim beds. Slower to build with, but avoids any tape related issues.
Posted : 18/03/2020 11:28 am
Onzadog
Yes. There’s typically around 100kgf on that spoke which all let’s go instantly. Getting through a bit of flimsy tape is easy.
maybe a dumb question but genuine thought UST only referred to the rim "hook" - is something else going on down in the area where the nipples are? ...and probably a different issue...a few years ago I looked at building a set of wheels with some sort of plugs instead of tape has that died a death?
Posted : 18/03/2020 12:05 pm
UST means the bed is permanently sealed so no tape. (though after pretty much everyone abandoned UST they introduced a "ust ready" format which can use tape or a strip)
Posted : 18/03/2020 4:25 pm
We had a wheel that'd broken a few spokes sat in our workshop a few years ago, and left on it's own, it snapped a few more that fired themselves a good 2 metres away. There's a good bit of force on them when they let go.
Posted : 18/03/2020 7:42 pm
Fraud so. It may be a minor pain to clean the rim off now. Get the tape on order before CRC and Hermes lock down!
Posted : 18/03/2020 8:36 pm
We had a wheel that’d broken a few spokes sat in our workshop a few years ago, and left on it’s own, it snapped a few more that fired themselves a good 2 metres away. There’s a good bit of force on them when they let go.
I left a wheel next to a radiator, pinged a couple of spokes! The spokes which failed had damage marks around the site of failure.
Posted : 19/03/2020 10:25 am
