Snapped MT-400 - Wh...
[Closed] Snapped MT-400 - What are my options?
Just recieved some bigger rotors today, in the process of installation I've snapped off on of the clamp of the calipers by being a **** and overtightening the bolt.
Anyway, now I've got a broken caliper and working lever, and I want to replace it.
The issue is I have no idea how to bleed brakes.
Here are the options I have come up with so far:
Buy an MT500 caliper for 22 pounds and suck it up like a man and learn to bleed and reattach brakes.
Buy a new caliper and lever for 40 quid and install that (might have to bleed anyway if I have to shorten).
Or is there an option of buying a better set of calipers (i.e. 4 pots) and attaching those? I did always think that the brakes were the biggest weakness on my bike. But I really like the lever I have right now.
Anyone know the compatibility?
TIA
Posted : 23/03/2021 7:38 pm
Ok so after rereading my post and judging by the lack of responses, I should ask the real question I am looking for the answer to:
Would I be able to attach a 4-pot caliper even if it has a banjo attachement? Or are there any other caliper options that would be suitable? Or should I just fix what I have now and upgrade later?
Thanks.
Posted : 23/03/2021 9:14 pm
Buy a torque wrench instead? Blimey never heard of anyone doing that before, about 10nm should do it. All the lower end calipers are very similar if 2 pot. None are more resistant to cranking up that tight though..
Posted : 23/03/2021 9:42 pm
@beanieripper
Yes frustration with a new adaptor and tiredness were the main factors. As you could expect I now feel pretty stupid. Oh well.
Posted : 23/03/2021 10:04 pm
I've done it don't worry all part of the fun..
Posted : 23/03/2021 10:15 pm
Belgianwaffle, send me a private message, I might be able to help.
Posted : 23/03/2021 10:19 pm
If you were going from a straight to banjo connection you would need a new hose. At that point it becomes uneconomical. I'd just fix what you have. Bigger rotors will help.
I’ve done it don’t worry all part of the fun.
Second this, have also trashed stuff being heavy handed.
Posted : 23/03/2021 10:21 pm
If I were you I would buy a Shimano bleed kit and other spares such as banjos from Amazon and replace the lever as you suggest.
Bleeding Shimano brakes is actually very easy. You can sometimes cheat just by screwing in the bleed reservoir to the lever, topping up with fluid and then squeezing the lever until all the air bubbles leave the system.
@BlipBloop
I'm assuming you mean caliper?
But yes I think I might have some mineral oil and I definitely bought a bleed kit.
Posted : 23/03/2021 10:31 pm
@wheelsonfire1
Sorry mate can't seem to message you on here. Can you email me on henrysmedcalf "at" yahoo "dot" com
please.
Many thanks
Posted : 23/03/2021 10:36 pm
Bumping to ask if I bought something like this:
https://www.tweekscycles.com/uk/shimano-br-mt500-deore-disc-brake-caliper-madbrmt500fr/?istCompanyId=56f52ebf-49f3-492a-9cbb-cb6ab0fc1bf0&istFeedId=33b89177-5114-4491-9c2a-09a3a7cb23b2&istItemId=ipxwraaqw&istBid=t&gclid=CjwKCAjwxuuCBhATEiwAIIIz0QsVVChM5Wiy-Lr_VbgWdjoThzgJ6bwTeWgzdhJCD0hvUPwhz8GKkBoCS3sQAvD_BwE&gclsrc=aw.ds
And I wanted to use the existing hose would I have to buy a new connecting insert and olive? Is it like the connection with the lever?
Thanks.
Posted : 24/03/2021 12:38 pm
That last caliper linked looks like it has a straight in connector with no banjo. From a quick google that’s what the mt400 has as well. I’d assume that would be a straight caliper swap 🤷‍♂️
Posted : 24/03/2021 12:50 pm
It looks to me like the Deore 4-pot uses the same hose. One of those on the front would probably be a good upgrade, if they're not too pricey. Bleeding brakes isn't super difficult, you just need to understand that you are forcing fluid through the system to displace any air. Often, you can just gravity bleed, where you just open the bleeder on the caliper and let fluid flow in from the reservoir.
https://bike.shimano.com/en-SG/product/component/deore-m6100/BR-M6120.html
Posted : 24/03/2021 1:11 pm
bear in mind that most new full shimano systems come with the hose detached from the lever. it's supposed to be set so that you can feed the hose through internal routing, then plug it in to the lever without bleeding. it works, most of the time. unless you're clumsy and squeeze the lever when the plug is out.
my point is that should you go down the whole new setup route, you'll need to be at least prepared to bleed it.
Posted : 24/03/2021 3:53 pm
Just bought a BNIB M6100 caliper for 25 quid posted which is nice... anyone know if the olive is pre installed inside it?
Cheers.
Posted : 24/03/2021 4:31 pm
