Small saddle bag
Small saddle bag
6 Users
Looking for a saddle bag I can swap between 2 bikes, so need some kind of clip on both bikes.
Only needs to be big enough for the following:
CO2 cartridges
Tyre levers
Tubeless repair kit
Multitool
Chain Links
Any recommendations?
Thanks!
Posted : 06/04/2023 9:03 am
 nbt
Ortleib micro sounds ideal, you can buy spare clips so the same bag can go on multiple bikes - and as it's mounted on the rails, it's fine with dropper posts. I use one of these (the smallest 0.5l size), plus I have a larger 4.1l pack with the same mounting for bigger days out (though the larger pack DOES attach to the post so not quite as good for dropers)
Posted : 06/04/2023 9:08 am
Not used it, but the fidlock one looks great, and easy to take on/off - but very spendy. Used to have an ortlieb one.that could also be removed quickly - unsure if you can get a second bracket though.
Posted : 06/04/2023 9:11 am
I use a Zefal Z Light Saddle Pack - Small
https://www.zefal.com/en/saddle-bags/305-z-light-pack.html
Can be moved between bikes in seconds and can be cinched tight to the rails. Also use a toe-strap to really hold it tight if required.
As seen here holding exactly what the OP needs:
https://imgur.com/ya6RIpy
Posted : 06/04/2023 9:29 am
Thanks for the suggestions. Forget to mention it needs to be dropper friendly.
Posted : 06/04/2023 10:00 am
<Recommend what you've got>
How about a tool roll with velcro straps? e.g. https://www.amazon.co.uk/dp/B096S53V3T?ref=ppx_yo2ov_dt_b_product_details&th=1
</end>
Posted : 06/04/2023 10:06 am
ortlieb!
Posted : 06/04/2023 10:18 am
