SLX Double & Ba...
[Closed] SLX Double & Bash Chainset - ring alignment?
3 Users
 Leku
With a double ring and bash guard chainset, like the SLX, are the rings in the same place as a triple or are they further outboard? i.e. does the mid rear sprocket line up with the mid-point between the two chainrings or the larger of the two?
Cheers.
JB
Posted : 16/07/2009 10:55 am
Some good info here: -
[url= http://www.parktool.com/repair/readhowto.asp?id=110 ]Parktool Chainline Guide[/url]
Posted : 16/07/2009 11:00 am
long story short..
same place..
you loose the outer ring and the bash is in it's place. i know of ppl who run it 2.5mm wider to supposidly get a better chain line..
Posted : 16/07/2009 11:09 am
