Slightly Confused A...
[Closed] Slightly Confused And A Bit Miffed ..... 10 Speed Query .....
After a quick look around for some new gearing bits I decided to give 10 speed a tryout.
After getting it all set up and tested its running sweet but I need to:
a) shorten the chain
b) need to get a spare powerlink or such like
This si where I am a bit miffed.
9 speed powerlinks are re usable but it would seem the 10 speed powerlock isn’t.
As I have a shimano chain is my only option of a “powerlink” type joining link a KMC jobbie?
I know I could get a couple of spare 10 speed pins but they are easily lost and seem over priced for what they are.
Any suggestions as to what I should go for?
Cheers,
Mark
Posted : 09/10/2012 1:40 pm
Nine speed powerlinks work, I know cos a mate snapped his ten speed chain on a ride and we fixed it with my ninespeed powerlink and it worked, no rubbing or funny noises and it shifted fine...
Posted : 09/10/2012 1:45 pm
The KMC 10 speed powerlink works fine on my Shimano chain.
Posted : 09/10/2012 1:51 pm
agreed on the KMC's.
http://www.ebay.co.uk/itm/230751995344?var=530045592642&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
The 9 speeds do indeed work... but they are fractionally too wide so you get a bit of play in them. I used one for 20 miles or so as an emergency, but took it off for a Shimano pin when i got home.
Posted : 09/10/2012 1:54 pm
Use KMC links, no issues with Shimano chains at all
Posted : 09/10/2012 1:56 pm
Been using 9 speed power links on my 10 speed chain ever since I had it. Broke the original connecting pin fitting the chain.
Posted : 09/10/2012 2:03 pm
I reuse 10 speed KMC power links on Shimano and SRAM chains, 4 quid for 2 in [url= http://www.decathlon.co.uk/master-link-for-a-10s-chain-id_5933615.html ]Decathlon[/url], they are branded KMC.
Posted : 09/10/2012 2:15 pm
+1 to both these - 9 spd work in a pinch, and get KMC rebranded as decathlon at £4 for 2 complete pairs
Posted : 09/10/2012 2:25 pm
Apparently the 10 speed Powerlock ones are actually re-usable. They're just harder to get apart and you may need pliers (or a special tool from Superstar).
I've been using the 9 speed ones and not had any problems though.
Posted : 09/10/2012 4:14 pm
Little known fact, but KMC make alot of the Shimano chain.
Posted : 09/10/2012 4:59 pm
Decathalon do them for £3.99 a pair
Posted : 09/10/2012 5:01 pm
Merlin do YBN ones for £2.26 (to be precise). They work the same as a Powerlink.
Posted : 09/10/2012 5:09 pm
I'm using a 9sp SRAM link on 9sp Shimano and SRAM chains and 10sp SRAM (road) chains. THis has been fine.
I did have problems with the KMC ones coming apart when i didn't want them to and have stuck with SRAM ever since.
Posted : 09/10/2012 5:12 pm
KMC 10-speeds are reusable. Also, they do seem expensive but they're normally packaged in pairs (ie 4 parts, 2 complete links)
Good tip on Decathlon!
Posted : 09/10/2012 7:23 pm
I've re-used the 10sp links a few times, I bought some pliers for opening the links, about £8 from CRC.
Posted : 10/10/2012 3:18 pm
My LBS wanted £10 for a sram power link. When I said I would give it a miss they said £5.
Posted : 10/10/2012 3:31 pm
