Slacken my bike.
[Closed] Slacken my bike.
8 Users
i have a 20 year old Marin that feels a bit odd compared to my later bikes.
Thought I would try and slacken it. Had some offset bushes that I bought when they first came out . They didn’t fit the bike I owned then and they don’t fit the Marin either. The bush is a fraction too big and the hole just a fraction too small.
Is there a brand that are known to have a reliable quality?
It’s new headset time and Superstar have a 2 degree angle set that will fit. Is 2 degrees too much of a difference? Normally superstar don’t have what I want in stock. Is a 2 degree headset from the same bin as a red anodised 25.4 , 600 mm handlebar?
Posted : 07/06/2019 7:31 am
Used Offsetbushings.com recently.
Just give them your model & year and they'll find the right size.
Hardware size dictates how slack you can go.
Fast postage and nice quality too.
Are you sure it'll fit 1 1/8th heatutbe? Seems pretty slack. Usually they are for tapered or 1.5 heattubes. I could be wrong, but worth checking again.
Posted : 07/06/2019 8:45 am
Think you can only get a 1 degree angle headset from Works Components for straight 1 1/8 headtubes.
linky
Longer fork will slacken it too so you could go 20mm to take off a degree, then with above that's -2 degrees.
I did this with my hardtail and went from 69.5 to 67.5 (66.5 unsagged) and it is now way more fun!
Posted : 07/06/2019 9:21 am
I have a 120 steerer tube with an external headset.
Will this fit?
Posted : 07/06/2019 9:23 am
Stating the bleedin obvious, but the longer fork route will also slacken seatpost / raise bb height and possibly wreck the geometry for climbing etc. so don't overdo it.
Posted : 07/06/2019 9:26 am
It will if your headtube is 44mm but it wont if your headtube is 34mm.  What size is your headtube?
Posted : 07/06/2019 9:30 am
That is true blackflag. I've done it on all my hardtails but never had full suss. I normally tip saddle down and move it forward to compensate and generally all has been good.
I take the approach of trying it out and if worse you can always revert back to standard
Posted : 07/06/2019 9:39 am
Offset bushings will lower the bb, a higher fork will raise it again, both will slacken it. What you will be left with is a slacker seat tube angle (slam the saddle forward on the rails) and a shorter reach and higher handlebars. I did this on a full susser (not as old school as the OP, but definitely pre- long, low etc.) : +20mm on fork travel, one offset bushing, 1.5 degree slackerer head angle. It worked well, but then I have never seen the need for really steep seat angles (and there are plenty of steep hills round where I am).
Posted : 07/06/2019 9:47 am
Mix 'n' match wheel/tyre sizes, larger wheel up front.
Posted : 07/06/2019 9:57 am
 Gunz
As an offset headset will rotate the bike forward around the axis of the rear axle wouldn't it give a steeper seat angle (albeit to a minuscule degree) or is my spatial imagination out of whack?
Posted : 07/06/2019 11:07 am
Offset headsets lower the front end around 3mm per degree (500mm a-c at 70 degrees).
RE different size wheels, I wouldn't bother trying a 24 in the back, though it would look cool.
Posted : 07/06/2019 11:24 am
