SKS Mudguard Repair
[Closed] SKS Mudguard Repair
6 Users
Having taken the mudguards off for the summer I dropped the rear and sheared the piece of metal where the stays meet the mudguard.
Any suggestions on how I could repair this, other than this pretty terminal problem they are in pretty good condition and I'd rather not have to buy another set right now.
Looks like this...
Posted : 05/07/2020 8:45 pm
I'd melt a hole through it with a soldering iron ,put a cable tie through it and another below the nut on the stay and then tighten them both together.
Posted : 05/07/2020 9:50 pm
I'd drill out the rivets
I'd make a new bridge out of aluminium
It's just a strip with two holes in and bent to shape.
Then I'd rivet it back in.
Posted : 05/07/2020 9:52 pm
Trekkinn have SKS Bluemels from £15....
Posted : 06/07/2020 7:52 am
Trekkinn have SKS Bluemels from £15….
These are bluemel 65s which appear to be £27 on Trekkinn.
Posted : 06/07/2020 8:28 am
I'd just buy some more. They last a couple of years then start falling to bits.
Posted : 06/07/2020 8:29 am
If you repair it with aluminium it will corrode away quite quickly in winter salt. The attraction is that the aluminium is easy to bend and drill.
A thin piece of stainless would be much better.
Posted : 06/07/2020 11:05 am
