SKF bearings:Worth ...
[Closed] SKF bearings:Worth the extra money?
[#3995091]
I have to replace all the bearings in my superstar evo hubs,SKF are five times the price! Are they worth it?
Posted : 21/05/2012 11:36 am
if it's five time the cost of rubbish chinese bearing then yes... any branded bearing (INA,FAG,etc) is better than un-marked ones.
I stick to my engineering guy's (guy @ my last place of work) philosophy, they maybe cheap but having to strip them out after a quarter of the time (if that) of decent bearing, doesn't make them so cheap.
Branded bearing normally cost me around £8-10 each (cheaper as sets), well worth the cost.
Posted : 21/05/2012 12:22 pm
Thanks for that, hand in pocket time! 🙂
Posted : 21/05/2012 12:38 pm
I dunno, but greasing them before installation is worthwhile IMO/E
Posted : 21/05/2012 12:39 pm
I was amazed at how many times more expensive they are than cheap ones.
What is the difference in manufacturing/materials which justifies the extra price?
Errr, think about what you've said. If they last a quarter of the time and cost 1/5, they're still cheaper than SKF et al.
I had some nice posh SKF bearings in my Power Tap, they didn't last very long at all, so I put the cheapest ones I could find in, on the basis that I'd just change them more often. They're still fine. When my MTB hubs needed bearings I just bought cheap again, happy to replace them more regularly.
Posted : 21/05/2012 12:53 pm
I am no expert but some of the differences i know of are the more expensive ones are generally stainless steel where the cheaper ones are chromium steel the balls in the more expensive ones generally will have a greater tolerance on the sphericallity (is that a word? they are more sphere shaped) of the ball.
Posted : 21/05/2012 12:54 pm
I was being generous on the length of time they last TBH for a more balanced argument, and that doesn't include the hassle that being a self destructed bearing can be if they seperate while in place (more likely with cheap rubbish), let alone the hassle of having to change them constantly.
IIRC some-one on here bought a pile of cheap bearing for the cost of 1 decent one, off ebay, after the first 3 had died within no time at all, he binned them.... this was my experience, as a local bearing supplier only sell chinese stuff.. I swapped bearing suppliers when they (bearing not supplier) died
Posted : 21/05/2012 1:12 pm
Deep groove radial ball bearings are not all made to the same standards with the same materials.
http://www.gmnbt.com/deepgroove_technology.htm
But if you have the dimensions of the bearings that you want
eg 12mm I/D x 28mm O/D x 8mm Thickness
then just type
[i]12 28 8 bearing[/i]
into google or Ebay and you can see the choice of manufacturers and prices generally available.
Posted : 21/05/2012 1:29 pm
