Size of solderless ...
[Closed] Size of solderless nipple for Canyon dropper/BX remote
I've just ordered on of the cheap eBay Canyon droppers for my wife's bike, and already have a Bran X lever in the spares box, as well as a bulk load of gear inner/outer.
Am I right in thinking I can just grab a solderless nipple to stick at the post end end? Any idea what size it needs to be?
Ta!
Posted : 09/04/2020 9:49 am
You can cut down the brass connector in a mains plug too, so I was told on here way back anyway.
Posted : 09/04/2020 6:52 pm
Excuse the daftish Q : I got a Canyon post from ebay recently - and I added to the PSA post one here. I paired it to a brand X lever.
The nipple at the post end is the standard gear cable termination. The lever end is the plain end. There was no need for an extra nipple.
Maybe you have a different generation of post / lever ?
Posted : 09/04/2020 10:23 pm
I used these
https://www.ebay.co.uk/itm/2-x-Solderless-Cable-Nipple-Motorcycle-Scooter-Bicycle-Quad-Boat-Car-Truck-Lorry-/254113042725
To achieve the same. I used the free end of the cable at the lever end with one of the solderless nipples. Makes adjusting the length really easy
Posted : 09/04/2020 10:45 pm
kneed
Subscriber
Excuse the daftish Q : I got a Canyon post from ebay recently – and I added to the PSA post one here. I paired it to a brand X lever.
Posted 32 minutes ago
Guessing op has the first gen lever that doesn't have a grub screw mate.
Posted : 09/04/2020 10:56 pm
My new Canyon Iridium/BrandX also has no clamp / grub screw.
It fits a standard brake cable end.
I happened to have a new lever, with clamp at that end anyway. One of the cheap ZTTO eBay ones - £11, better than the original.
Posted : 09/04/2020 11:15 pm
Guessing op has the first gen lever that doesn’t have a grub screw mate.
Ah - ok. So my input isnt helpful then.
Posted : 09/04/2020 11:49 pm
Cheers Dai3015 -I'd taken a punt and ordered a couple of those already, so good news!
To bushing plan as well Poopscoop, will keep that in mind!
Kneed -yeah, the lever I have is from a failed 1st Gen. The moulded end is at the lever and it had a clamp on nipple at the post end 🙂
Posted : 10/04/2020 7:44 am
