singlespeed/track c...
[Closed] singlespeed/track chain - how tight ?
Just popped back wheel off new track bike to change tube and faffing about refitting. Am I doing it right - tighten drive side nut while pulling wheel back tight. This leaves wheel offset towards drive side. Push straight and then while holding central tighten up non drive side. Chain is taught but not solid tight.
....and yes, I should have noticed how much tension was in it before undoing ๐Ÿ˜ณ
Posted : 07/09/2013 10:45 am
 kilo
Spin the cranks and turn the bike horizontal / parrallel to the ground with the chainset side up, the crank should spin without the chain dropping off. A track chain need some slack. I was told to do non drive side nut first as the tightening pulls the wheel back rather than lets it creep forwards. MIND YOUR FINGERS if you spin the cranks
Posted : 07/09/2013 10:59 am
Thanks kilo
Posted : 07/09/2013 11:03 am
right,done, and I have about 1 cm of movement both up and down from static at the top in the middle of chain, seems fine
Posted : 07/09/2013 12:23 pm
top tip which made job easier ! ๐Ÿ˜›
Posted : 09/09/2013 11:17 am
 will
Can you not get chain tugs?
Posted : 09/09/2013 11:24 am
will - probably, but likely not allowed on Velodrome
Posted : 09/09/2013 12:06 pm
0.5cm at the slackest point is the norm. And yes the tip about locking the non-drive side first is a good one. Chainrings and sprockets do not seat perfectly, so you will probably have a tight spot, despite a little slack. You don't need a chain tug. I find hanging the bike from the front wheel in the garage helps. And get a nice big 15mm socket spanner for teh job.
Don't forget that if you change gearing, the axle will move slightly too.
Posted : 09/09/2013 12:22 pm
Thanks TiRed - yeah, I ended up with it in that configuration in the work stand, to let gravity pull it tight as I only have 2 hands ๐Ÿ™‚
The max I can move it is about 1cm up and the same down, so 2cm overall, when in the tightest spot
Posted : 09/09/2013 12:27 pm
