singlespeed knockin...
[Closed] singlespeed knocking sound?
Hi. just recently bought a vitus vee 1 singlespeed from chain reaction cycles. From day one I have noticed a strange knocking, clunking noise coming from the bike when pedaling, which i think is increasingly getting worse. its not coming from the bottom bracket, but two things that i have noticed is that the chain has different tension in places and also there is slight play in the rear cog (is this normal). do you think one of these is the reason for this? appreciate the advise/help guys
Posted : 05/11/2012 9:01 pm
Could be, in its tightest spot it still needs about 1cm of vertical movement, the cog should have zero play in it, tighten the lockring.
Posted : 05/11/2012 9:05 pm
a little play isn't unusual.
tough to diagnose a clunk.
Posted : 05/11/2012 9:09 pm
but say i get 1cm vertical movement at one part of the chain, rotate the cranks, then find that this part of the chain has 2cm movement, is this normal?
Posted : 05/11/2012 9:15 pm
yes
Posted : 05/11/2012 9:17 pm
sorry not really a clunking sound but a knocking yes ๐Ÿ˜ณ
Posted : 05/11/2012 9:18 pm
Check the chain ring bolts are all tight.
Posted : 05/11/2012 9:20 pm
 kilo
If it's not coming from the BB where is it coming from - not being rude but on my fixed commuter the last two lots of clunking have been the sealed BB failing
Posted : 05/11/2012 9:26 pm
Is it a shimano freewheel ? if it is they can make a knocking noise not allways in time to the pedal stroke.
Posted : 05/11/2012 9:27 pm
so theres no way the knocking sound can come from the chain? just that my no it all old man is adament its a faulty chain ๐Ÿ™„ ill give the bb a good strip/regrease tommorow hopefully that is the problem
Posted : 05/11/2012 9:39 pm
check your knees?
Posted : 05/11/2012 9:40 pm
'Knocks' tend to be more bb based as the frame amplifies the sound more. A click or tick or anything gritty sounding would more likely be freewheel. Hard to tell with actually hearing it. I take there is no noise when free wheeling?
Jez www.followingthechainline.blogspot.com
Posted : 05/11/2012 10:08 pm
