Single/double/tripl...
[Closed] Single/double/triple.... Pros and cons of each.
 br
[i]Br can you convert a triple into a single ring setup then.
What nw would you recommend?
[/i]
Yes, just put a N/W onto the current middle ring position and buy an expander (either Shimano or SRAM depending on your cassette).
tbh though, wait until your drivetrain is knackered and then buy:
Hope 30T N/W
Hope 40T expander
Shimano XT 10-spd 11-36 cassette
Chain
Jockey Wheels
Narrow chainring bolts
Or, as I will be doing soon; a complete Shimano XT 11 speed setup, minus the cranks.
Posted : 24/08/2015 11:59 am
Suppose there's weight saved Steve but didn't really notice it! Thought I'd try it to simplify the bike really, one shifter and a dropper post remote is all I need to worry about now. To be fair I live in Essex now so pretty flat really, no massive hill's so it suits me, could have went for a 32t which I might try later.
I was going to try a double chain set but looking at the orange Web site they reckon the bike isn't suitable for it and to use a triple and bash ring. Didn't seem to make sense to go this route.
Posted : 24/08/2015 12:08 pm
Oh yeah, didn't need to buy new chain ring bolts with the hope 30t as the raceface ones fit fine.
Posted : 24/08/2015 12:10 pm
Is freewheeling on a road descent a huge compromise?
Yes, when my tea's at home waiting for me. 😉
Posted : 24/08/2015 12:17 pm
Mastiles Lane from Kilnsey and Barden Moor from Rylstone are probably the two I struggle with but then even with a granny ring I've never cleaned the latter - there's that bit just after the gate, I just run out of oomph
I've only ever cleaned the Rylstone climb in my easiest gear on granny ring. Dab fairly often on the last bit. But the fact that I have done it means I'd be forever irritated to not even have a shot at it.
The climb over from Arncliff to Kettlewell is so steep I doubt I'd do it even with a granny ring. In
Ditto to that! Virtually everything at that end of Wharfedale is pushing territory for me.
Posted : 24/08/2015 12:33 pm
 Alex
NickC is right that some FS bikes are optimised for a single ring. Having two bikes running 1x10 (with a 40T), I found going back to a front mech on my 29er really strange. And it didn't seem to have the super low gear I was expecting. Once that drivetrain wears out, I'll go to 1x11. Even in the Malverns 1x10 (32T/40T) on my Aeris is fine. Gets a bit tiring at the end of the day, but I prefer the simplicity / clearance / etc of a single ring.
The advice offered is good tho; ride in the middle ring, see if you miss the other ones. Zee cranks are pretty heavy, not sure you'd save much if you went that way!
Posted : 24/08/2015 12:38 pm
Okay so there are some things to take away and think about here then.
I find that I use the granny ring a fair bit around here as there are so steep bits that I just havent got the legs for!
I dont think Ive ever used the big ring either.
One thing for certain is that I need two bolts for my granny ring as Ive just found its only held on by tow out of four??
Ive snapped the clutch engagement lever off my rear mech as well !
Posted : 24/08/2015 4:40 pm
Dibbs - Member
Learn to tuck....
I stupidly went out for a ride with some mates on a 2x9 mtb with them on roadies on the road, up and down I had no issues, tucked I was with one of them all the way down the hills. It was the flat that was the issue. But then again I don't do very much on the road on the MTB normally.
This shows where the differences are
In reality the SRAM is the 2x killer due to the 10t, the Shimano will always be less range (unless you get the 45t)
engaging a climbing gear has gone from:
'click'
to:
'click-click-click-releaseshifter-click-click-click-releaseshifter-click'
From 1 to 11 faster than you can say Spinal Tap
Posted : 24/08/2015 4:52 pm
@martinhutch
The last time I did the Rylstone climb was at the end of the YD300 when you spotted me on the other side - I think having 280Km in the legs is a decent excuse 😀
I very nearly got the bridleway out of the car park at Buckden without dabbing last Saturday and that was with the bike loaded up for bikepacking plus a bit of damp under the trees after the Friday rain. It's probably the easiest climb out of Wharfedale - well worth a try.
Just thought of another that I've not cleaned: the BW up out of Stainforth. Another steep one with a loose surface.
Posted : 24/08/2015 4:57 pm
#TRIPLE4LYF
#PreferablyBiopace
Posted : 24/08/2015 5:06 pm
The advantages of a single chainring are also that you don't have to make front gear changes which are the ones that people mess up as they are reluctant to back off the power while it shifts thus damaging chains , chainrings , frames etc . You also get better clearance , no wondering what front ring to be in , you just put it in the gear you need . Lighter as well . Disadvantage is a smaller ratio of gears although 420% works for plenty of people .
Posted : 24/08/2015 7:40 pm
Page 2 / 2
