SIngle speed setup
[Closed] SIngle speed setup
4 Users
I bought a Dmr simple tension seeker kit to convert my bike and was also sold a sram pc1 chain at the same shop. Because i couldnt get the chain length close enough using the supplied 16t cog i am now using a 9speed 14tooth from a cassette and a 9speed 36t front ring. The chain length is ok and everything works ok when riding, but the chain runs to tight in the tensioner as it is apparently designed for 9 speed chains not the fatter single speed chains. DO i need to swap the chain to a 9 speed?
Any advice please?
Posted : 31/05/2010 8:16 pm
Easiest thing to do is cut or file out the roller so it fits the wider chain a bit better. Think I've read of a few people doing this.
Posted : 31/05/2010 8:23 pm
Cheers Tom. I was thinking along them lines but wondered if a bigger problem may be compatability between 9speed cogs and the single speed chain but they seem to work together. So i may get the file out!
How can i get more options of chain lengths as it seemed quite critical as the tensioner doesnt have much movement for taking out the slack?
Posted : 31/05/2010 8:33 pm
Half link like [url= http://www.charliethebikemonger.com/userimages/procart3.htm ]this[/url] might work (scroll down to KMC Half Link). Vertical dropouts are a bit of a pain in the arse for SS, I'm going to be going through the same problems soon as I'm *this* close to switching back to SS 🙂
Posted : 31/05/2010 8:38 pm
Use the other kind of tensioner, that pushes down on the chain. Or run the chain under the roller. My mate did this with no problems.
I found with vert dropouts that the wheel used to get pulled offline slightly. I think this was caused by the disc brake. Now got a scandal with sliding dropouts and a chain tug, much better.
Posted : 31/05/2010 8:40 pm
 IanW
You will need to file out the roller for that chain. Alternativly you could get a 3/32 chain which will fit in the groove and whilst your at it get a half link version which allows more variation in chain length.
If you are going to use sprockets taken from cassettes its best to tension the chain up, I found them a little more likely to jump.
I bought a nice half link chain from charlie the bikemonger, they do strech though.
Posted : 31/05/2010 8:43 pm
Another stupid question!- A half link chain is all half links but can you fit 1 half link to a normal chain? 😳
Posted : 31/05/2010 8:48 pm
I am tensioning upwards. The 36 front is brand new but was not bought for this bike i couldnt get the supplied 16t to tension up or down there just was too much slack in the chain.
Thanks so far youre giving me plenty to think about.
Posted : 31/05/2010 8:52 pm
 IanW
Yep, and that will give you the adjustment you need.
[url= http://www.charliethebikemonger.com/userimages/procart3.htm ]half links and stuff[/url]
Posted : 31/05/2010 8:53 pm
Yeah with a half link (one of which can be put into a normal chain without any problems) you should hopefully be able to get it tight enough to tension upwards which looks much nicer 🙂
Posted : 31/05/2010 8:54 pm
Excellent guys. So i need a file and 1 half link then i can get the original 16t cog on [hopefully!] I think thats all for now then.
Thanks 8)
Posted : 31/05/2010 8:59 pm
