Now then, i'm thinking an converting an old GT into a singlespeed for commuter use. I've seen some kits on the net ranging from 16-50 quid. Has anyone out there got any advice for me if you did the same. I've looked at Charliethebikemonger.co.uk for kits but don't know where to start or what i really need
Any help greatfully received
Dux
you need either a whole new rear single speed wheel or some spacers and a cog plus a tensioner. simple as that.
easy but some kits only fit cirten size hubs i had a 7 speed hub and the kit wouldnt fit coz it was a 9 spd one
I did mine really cheap - just got a gusset single speed converter, and a singulator chain tensioner device from someone on here and shortened the chain.
Something like this on your rear sprocket to make it look better:
http://www.cyclestore.co.uk/productDetails.asp?productID=13844
Or you can use the spacers from an old cassette to do the same thing.
Chain tensioner like this:
http://www.cyclestore.co.uk/productDetails.asp?productID=8823
And on the front just use some single chain ring bolts and remove the large and small chain rings. If you buy the parts above new then your looking at about £50 but put a wtd add in the classifieds and people may have what you need
My singlespeed ws built up at the weekend using conversion kit from chain reaction for around £25 (would need to have a look to see which one) and on the front an old chin ring was used.
First ride was on sunday, sunday night I was completely nackered but was smiling ear to ear!
Thanks for the help you lot, seems an easier conversion than i thought. Robbo1234biking cheers for the links. Should be SSing to work after Easter
Just give a bit of consideration to gear choice - what is fine off-road (32/16 being the "accepted norm") gets very spinny on the road.
I use a 44t big ring in the middle ring position and 16t on the back with slicks for commuting around rolling Somerset...
Oh, and some people think chain line is important too
Thanks for that but i live in Lancashire where we have them proper hills. Plus my ride to work isn't all road, thanks for the heads up though
when i did it i just used a regular casette and a rear mech with a cable from the barrel adjustor to the clamp bolt to keep it on a middle sprocket. easy! some get nicked the bike though. grrr
dux - if your 7 speed block is a screw on, then you wont be able to use the standard spacer kits. I know this because I tried it 🙁
Then you have the best solution of all. Screw on bmx freewheel, shift some axle spacers around, re-dish the wheel and you're away.
How old is your GT? Does it have horizontal or semi-horizontal dropouts?
Just done mine and had enough of spinning out on the way to the trail.
Just ordered a road cassette.
It's fun when you hit the trail but I have 4 miles of roading to the trail at jogging speed.
You'll like it though! (fun building/riding)
You make it sound all so simple 😯
For anyone with patience, a spoke key and the ability to read, it is.
