Show me your Pipedr...
[Closed] Show me your Pipedream Scion.
 2POC
My blue frame is being delivered tomorrow. Can't wait.
Posted : 05/06/2011 1:56 pm
I'm wanting one of those, I'm very envious. When you get it weigh it and post the result. It'll make loads of us very happy, and if it's in Cotic Soul territory it'll shift bucket loads of frames for Pipedream...
Posted : 06/06/2011 12:08 am
 2POC
Sure will. I'll take some photos of the build too. Both won't be until tomorrow due to work commitments.
Posted : 06/06/2011 7:45 am
 PJay
I can show you a Pipedream Sirius, it should be identical to the Scion except for the sliding dropouts and thicker stays. According to the Pipedream [url= http://www.pipedreamcycles.com/FAQ_2010.html#faq4 ]FAQ[/url] the Scion should be about 250g (half a pound) lighter than the Sirius.
Posted : 06/06/2011 8:34 am
Looking forward to pics.
I really like the ride from my R853 but not the weight.
For a geared only option the Scion seems bang on.
Now hurry up with pics.
Posted : 06/06/2011 10:54 am
250 grammes lighter? That can't be right? Again pipedream themselves say just the sliding drop-outs weigh 300g. No sliding drop-outs, skinnier seat stays and only half a pound weight saving? I think their scales are faulty.
Still over 5 pounds for a medium, are they using tubes? or is it solid steel bar
Posted : 06/06/2011 12:10 pm
Is the Scion not the same as the older style Sirius without the sliding dropouts? Different steel perhaps?
Posted : 06/06/2011 12:55 pm
 sv
They are loverlllyyyy...
Posted : 06/06/2011 1:13 pm
 john
Swoosh - I've wondered about this, I've got an old sirius, which had the same geometry as the new one/scion, but uses their own tubeset (which they said is roughly equal to reynolds 631). They then changed to 853, but it sounds like it actually got heavier through some last minute changes for CEN testing. I have seen 5.7lbs quoted for the new one and 4.8 for the old (source - a bloke on the internet). So they've now taken the dropouts off and made it only a little heavier than the old one. Is 853 that much better, even in a heavier frame?
Either way, mine is lovely to ride, so I imagine the scion will be good - I keep thinking about getting a full suss, then I go for a ride and remember my current bike is awesome. Ruins my plans for new shiny things.
Posted : 06/06/2011 1:29 pm
@PJay - nice bike! Looks like a ....... real mountain bike. £349 seems a steal for such retro modernity.
Posted : 06/06/2011 2:04 pm
My 19.5'' frame was quite portly 5.5lbs +
Posted : 06/06/2011 2:14 pm
 PJay
To be honest I think that the weight thing is a little over done. I didn't weigh my frame, just swapped the parts across from my 853 Inbred and the total build weight didn't seem to differ much and I certainly can't feel it when riding; that extra weight (if it is there just seems to vanish in the general mass that is my bike). The WMB test that the Sirius won against some stiff competition did laud it for those desireable steel qualities (and it even built up into the lightest bike on test if I remember rightly) so if it is a tad portly it doesn't seem to have affected things 'off the scales'.
Equally I do get that people don't want their bikes heavier than they need be, but weight doesn't necessarily equate to 'bad'. I suspect that the Kinesis Decade Virsa is a lighter steel frame, but then there's been talk about cracking seat tubes, I'm pretty certain that the Cove Handjob's lighter but there have been issues with crumpled downtubes then again everyone seems to love the Orange P7 despite the fact that it makes the Sirius look seriously under-nourished. I suppose we could call the Sirius 'robust' (which to me is a good thing) rather than athletic.
The Sirius (and I suspect the Scion) isn't a race whippet, but if that's what you really want steel probably isn't the best choice anyway. If I were buying now I'd probably choose the Scion over the Sirius as I don't need the sliding dropouts, there are plenty of other contenders out there too. I really like my Sirius (and I tend only to pootle about on country roads and trails) and am really happy with what I've got.
As far as I can make out the Scion is identical to the Sirius except for the loss of the sliding dropouts and16mm as opposed to 19mm chainstays. I assume it's CEN tested too.
But the Scion will still have dropouts! They've had to replace 'em with something so you're not going to lose anything like 300g.
I was pretty deflated after getting my Sirius when everyone went on about the weight but after spending a while getting it set up right, the more I ride it the more I like it. If it was lighter would it ride better? Perhaps but then again I like the fact it's a little less 'waggy' than the 853 Inbred, a lighter frame might be more flexy. In any event for me it's the ride that counts.
Posted : 06/06/2011 2:37 pm
 2POC
Should be home by 8 so i'll try and get some photos of the frame up tonight (hopefully the wife was in when DHL turned up)
Posted : 06/06/2011 6:16 pm
 2POC
Posted : 06/06/2011 6:18 pm
Here's mine, at long last....
Due to the mismatched valve caps and the fact that the tyre/wheel logos don't match up, it rides like an absolute dog. 😉
Posted : 06/06/2011 7:07 pm
 2POC
Like it toxicsoks
Frame's 5lbs on the nose with my digital scales.
Thomson seat clamp and cane creek headset fitted.
Posted : 06/06/2011 9:14 pm
Toxicsocks - what size is that and what travel are the forks? I'm currently torn between a couple of frames and the Scion is well up the shortlist...
3rd edit: 5lbs - what size is that?
Posted : 06/06/2011 9:16 pm
 2POC
18"
Frame was was measured on dodgy scales from the kitchen!!
Posted : 06/06/2011 9:23 pm
My Curtis SS is all 853 and weighs in under 4lb. These pipedreams are a little bit porky, are they not?
Posted : 06/06/2011 9:24 pm
Frame is 19.5"
Forks are 120mm Rebas.
Posted : 06/06/2011 9:43 pm
Cheers guys.
Posted : 06/06/2011 9:45 pm
Your Curtis doesn't have to pass CEN because its custom, and the rider is a waife. 😉
Posted : 06/06/2011 10:01 pm
You beat me to it!! 😆
Posted : 06/06/2011 10:12 pm
I was gonna point out the price difference and waiting times but it seemed cruel...
Posted : 06/06/2011 10:14 pm
Curtis took less time than a Pipedream
Posted : 06/06/2011 10:47 pm
Touchy...
Posted : 06/06/2011 10:50 pm
No, just trolling thanks
Posted : 06/06/2011 11:00 pm
Posted : 06/06/2011 11:04 pm
Do look nice don't they. Looks like the same colour I had my old Rockhopper powdered. Too heavy though, I know they're cheaper than than a Soul but they're more than a Skinny Duster and the Duster's lighter. I'm looking at the Charge now I think, anyone got one? What are they like?
Posted : 07/06/2011 3:51 pm
