Shortest fork that&...
[Closed] Shortest fork that'll take a knard
[#6269903]
I've tried to do a search, but nothing's come up that'll quite answer my question. So has anyone done any actual research into what's the shortest fork you can fit a Knard into?
I want to turn my old ss tinbred into something for the sandy trail I know near my parents place. I've got a 26" on one carbon fork and that's good for a 2.4" 29er Racing Ralph, but I don't think anything much larger will fit. Then I've seen it fit on a niner carbon, but that's probably a little long for my intended purpose.
Maybe all the options will be too long and I should go for a fat fronted tinbred instead.
Posted : 14/06/2014 4:18 pm
I'm told 3" is not wide enough for sand (let alone what you might get on the rear).
Posted : 14/06/2014 4:25 pm
They are sandy trails, with occasional meter long sections of deeper sand, rather than trying to ride on the actual beach.
Posted : 14/06/2014 4:43 pm
I'm running a Knard on a Dually rim in my 445mm AtoC Salsa Cromoto with adequate room to spare. I wouldn't want to go much shorter as it's the height rather than the width I imagine would be the issue.
I ride in and around Thetford and that's surprisingly sandy in places. It's much better than the 2.4 Ardent it replaced but I imagine a full blown fat tyre would be better again.
Posted : 14/06/2014 4:57 pm
Hummmm, I think an on one fatty fork and a proper fat wheel might be best.
Posted : 14/06/2014 5:46 pm
The fatty fork is the same length as the Niner iIRC.
Posted : 14/06/2014 8:47 pm
Thanks! That would have been a schoolboy error. Any other fat forks out there as short as the Jones unicrown that aren't so expensive?
Posted : 15/06/2014 6:35 pm
The std 100mm spaced Pugsley forks would suit.
Happy with a 4" fat tyre and a 29er+ tyre.
About £100.
Win and indeed Win.
Posted : 15/06/2014 7:55 pm
knard technically fits in a 425mm salsa (mtbr)
Posted : 15/06/2014 9:42 pm
I'm sure it's closer than that on my 425mm Cromoto. Possibly different rim?
Posted : 15/06/2014 9:48 pm
I've found it's not so much the knard but more the rim width. For example, my knard on a rabbit hole will not fit my 445mm salsa cromoto, but if I mount it on my flow ex it will. So the question is what rim are you gonna use?
Hope that helps
Posted : 15/06/2014 9:54 pm
Interesting.
A Knard on a Dually fits fine in my 445mm Cromoto.
Does the extra 5mm rim width make that much of a difference? 😕
Posted : 15/06/2014 9:59 pm
No I'm lying.
Posted : 15/06/2014 10:12 pm
Seriously, I spent a fair bit of money on a built up rabbit hole and knard only to find out wouldn't fit. It went in at around 15 - 20 psi but the knobs still rubbed quite badly against the fork. I'm thinking of 'modifying' the fork ever so slightly to make it work.
Posted : 15/06/2014 10:25 pm
It's the width on the jones Unicrown that's good - 135mm spaced. The length is only 435mm.
Posted : 15/06/2014 10:26 pm
@ BJ - No one said anything about lying 😉
Knard on a Dually in my Cromoto:
I based my build albeit a Dually rather than a RH on this:
Posted : 16/06/2014 10:10 am
That's an interesting looking frame- Knard in the back too! What is it?
Posted : 16/06/2014 10:14 am
Its a home built frame buy a chap over on the MTBR forum.
More about the frame and some additional pics here >>>>
http://forums.mtbr.com/surly/pics-rabbit-hole-knard-non-krampus-frame-837160-4.html#post10747233
Non suspension corrected too 8)
Posted : 16/06/2014 10:57 am
Damn! I knew I should have gone with a dually!
Posted : 16/06/2014 7:35 pm
I've kind of given up on the idea. My Ragley td1 is designed around a 440mm fork. So I'm thinking to maintain the geometry with a knard I would need a 425mm a to c. White bros do a 425 rock solid, which would be perfect i reckon, but I don't want to pay more money out. Ah well.
Posted : 16/06/2014 7:40 pm
