Has anyone managed to squeeze a zee mech onto a 40t cassette adapter and get it working?
Friend has and working fine... ๐
yep mine works fine too. Chain can be a little slack in smallest gear so you need to be accurate with chain length and line
Yup.
Yea mine is working fine, didn't need to use the replacement 'b' screw either
Thank you ^. I'll have something to keep my busy for a bit this weekend when it's raining cats and dogs. What about 42t? Just out of interest.
I've got a SS cage on my XTR rear mech on my Tallboy and it is working absolutely fine with the Hope 40t. I double checked the chain length and dropped the shock to make sure it would not be a problem at full compression but it all works spot on.
I use a Zee FR mech with a Hope T-Rex 40t on my Trance with no problems.
Oneup say 40th is fine as long as your frame has less than 25mm of chain growth.
